Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Convergence problem??? picture looks like a 3-d movie with out the glasses.. The red seems more out of wack then the blue or green...from what I've read on the web the ic's are bad called repair man said convergence amp was bad >>>>??? I have the same problem. Model KP-65WS510 Was perfect in every way yesterday. Today, turned on the set and have a contoured picture, with green lines streaming horizontally across the upper third of the screen. Colors are off vertically and convergence function moves a tiny bit and not enough to fix this very drastic off-set of colors. I would like to attempt to repair this myself? What would I need and where can I find the approved procedure/parts? Thanks for this excellent help forum!
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
  • Edward
    Edward Feb 14, 2009
    Your TV has a convergence problem.
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Other problems you TV may have in the future...
    CRT Fluid gets Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
I also have the same problem turned on in morning and pop 3 screens won't line up. I've been told that there are 2 convergence amps and that there are fuses on board G. I'm Triing to locate service manual download from anyone who has also had this problem, If you can help please contact.
Posted on Dec 01, 2008
  • 2,326 Answers
  • 4,889 Answers
I would suggest replacing both convergence IC's and all the resistors that hold the Green convergence. You should have a service manual so that you can trace which IC and resistors holds the Green convergence. By the way you need to do a little bit of soldering as well..
Posted on Mar 03, 2008
    Genius:
  • 3,587 Answers
Yeppers..those chips are soldered(more like welded) into the board, and usually runs you around 300 to 400 buckos..
  • Patrick Michaels
    Patrick Michaels Mar 03, 2008
    it's micro circuitry soldering, which you'd need a special soldering set up for(the kind that sucks as it solders)..
TV picture looks like a 3-d movie without 3-d glasses.
Ur convergence is dead.U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Buy a convergence kit at Tv repair world.com Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 05, 2010 | Hitachi 53FDX01B 53" Rear Projection...
My rca r52wm24 HD/TV monitior,is having ploblems with the picture, last night all of the suden the picture looks like a 3d movie with out the glasse, what is the problem
the problem is called convergence.this model was made with 2 options for convergence.first go into menu of tv,find convergence.if it has auto convergence activate it,IMPORTANT dont do any thing until its done(it will reach 100%,you can see it on the screen.the 2nd option is manual convergence,in that case you have to adjust the red onto the green then blue onto the green,DO NOT MOVE THE GREEN.both red/blue will move up and down,left and right.
Sep 24, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue Halo - convergence issue with 43Hx70
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
there is a way of lining the colours up in the service menu. to get into the service menu pres the "mute" button and then hold down the "mute" and "menu" button and the same time. this has to be done quickly. you then navigate to a screen which will have black square's on it. you will see the colurs that need to be lined up. it the colours wont line up. you will have to replace the convergience IC's. hope this helps you
Aug 05, 2008 | Televison & Video
Check the resistors by the STK ic's, should be 2.2 ohms. Under the heat sink, also check the 1.8 Ohm 1W, fusible resistors found around the area as well.
Good Luck.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Picture Quality
Sounds like the convergence ICs this is a common problem in all projection tv as the ICs have a lot of work projecting the correct alignment. You will need to replace both ICs at about 10.00 each. Also check the resistors right next to the ICs cause usually 1 or 2 of them will go open when the ICs give out.
Feb 03, 2008 | RCA P61960 61" Rear Projection Television
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Red duplicate image outline of picture.
you have lost red convergence. which ussally means one or both of the convergence amps need to be replace.. but it could be a resistor. does the red cross move up or down or side to side. how about the blue does it move in eather direction. this will let me know if both are bad
Jan 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
224 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
