I don't know if you mean the headlight bulb, or the headlight.
When you open the hood and look at the headlight assembly. At the top between the turn signal there is a black plastic wing nut. Unscrew that wing nut to remove the side marker light. After removing that nut persuade it to slide forward. That's the only thing that locks it in. Untwist the socket to replace the turn signal bulb. Since that is out now...There are two more Wing nuts just like the first one that hold the headlight assembly in place. (The black plastic piece the headlight is mounted to) Remove these two wing nuts and lift up on the whole assembly. Those are the only things that lock it into place. Once you slide it off the studs the wing nuts were on. Unplug the plug from the back of the light (use a flat screwdriver to lift the tab a little). Twist the round plastic ring that holds the bulb in. The bulb should pull out now. Don't touch the new bulb with your fingers as it is a halogen bulb and the oil on your fingers will cause a hot spot on it, causing it to fail SOON. If you happen to touch the glass part of the headlight bulb, clean it with rubbing alcohol. Reverse the steps...go eat dinner.
SOURCE: Olds silhouette heater blows cold air
as long as the engine temperature is normal, i would suspect a clogged heater core, the dex-cool antifreeze is notorious for building up deposits in cooling system. have heater core flushed first to see if it makes any difference
SOURCE: How difficult is it to change the 02 sensor on a 2001 Oldsmobile
it is very easy you unscrew the sensor from the housing and then follow the wiring and unplug it from there.
SOURCE: 2001 Oldsmobile Silhouette shifts into gear hard
try having your transmission filter changed there only about 15 - 20 bucks but you will have to buy transmission fluid. ive seen that solve that problem in a few vechiles. if you do it yourself there is a magnet located in the transmission pan that you have to remove to change the filter and if it is full of metal shavings i suggest asking a local transmission shop about having trouble with that type of vechicle
SOURCE: changed battery oldsmobile 2001 silhouette
a. try turning the key to accessory and leaving it there until the error light goes out. b. if you haven't yet, drive it 20-30 miles and let the main computer reset itself.
hopefully, that should solve the problem!
good luck!
SOURCE: 1999 Oldsmobile silhouette brake light and tcs
check the abs sensors common to hit or damage the wiring or knock connection loose when doing a brake job the traction control system[tcs] is tied into the abs system
