Question about Audiovox MVDVD4 Car Video Player
Audiovox MVDVD4 My player is spinning the disk but saying NO DISK any idea how to solve the problem,we have tried several disks.
  • 3 Answers
Just stumbled upon this as I was searching for a new MVDVD4 and thought it might help you out!! :
When the van was a little over 3 years old, the DVD player suddenly quit working. I would put in a DVD, the player made some noises like it was trying to read the DVD, then the display would say "NO DISK".
As it was out of warranty and I have a background in electronics, I opened the player. After playing around for a little while, I was able to fix the player real easily. If you have the same problem (and the player is out of warranty), open up the DVD player by removing the screws and breaking the seal. I blew out the inside with compressed air, but I doubt this made a difference. The problem was that the DVD was not spinning. The spinning mechanism under the DVD tray was not starting like it should. I carefully sprayed a couple drops of WD-40 (well actually Remington's Rem Oil) where the metal rod the spinner sits on goes into the motor mechanism that spins it (it will make sense when you look inside. It is where the little metal rod goes into the plastic casing). After a couple of drops of oil, the player worked fine again.
Posted on May 29, 2008
When i load a disk it says loading then it sayd no disk
Take a Q-Tip and rubbing alcohol and gently clean the laser lens, allow several minutes to dry before use, if this fails! replace the player because laser assembly not cost effective.
Mar 06, 2012 | Audiovox D1788 7 in. Portable DVD Player
When i load a disk it sayd loading then it says no disk
Grab a Q-Tip and rubbing alcohol, gently clean laser lens and allow several minutes to dry, if this fails! it is cheaper to replace the player.
Mar 06, 2012 | Audiovox D1708 Portable DVD Player
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
I DO NOT HAVE INSTRUCTIONS FOR THE AUDIOVOX MVDVD4 DVD PLAYER IN MY VEHICLE AND I AM NOT GETTING THE SOUND. DO I NEED TO TURN MY RADIO TO A CERTAIN FREQUENCY? THANKS
Most FM modulators most commonly run on FM frequency 88.1 or 88.3 but usually have several options, so play arround with the stations in that range, and see if you get sound, also look under the dash for a toggle switch of sorts, sometimes the modulators have to be turned on..
Aug 14, 2009 | Audiovox MVDVD4 Car Video Player
When we insert disk it says "No Disk" and will not play.
Try a known good disk if that don't work the laser assembly is bad. I you like you can purchase a laser assemby, and install it yoursef. It is not that esy to install.
Jun 28, 2009 | Audiovox D1718pk DVD Player
Install an disk and it will not load says "No disk"
have you tried cleanig the lens and/or the disk
Jun 04, 2009 | GoVideo Go Video DVD/VCR Combo
No Sound on Audiovox MVdvd4
This is where I found the manual...it was a challenge but I got it...and there are several versions it appears so you decide... Here is the primary link..then enter the code shown http://www.devicemanuals.com/guide/pdf manuals/Audiovox/Audiovox-MVP401V-MVDVD4-Owners-Manual-TkRVMk1EST.html After that this is the actual download site and link.....I hope this helps and good luck...also thanks for rating my effort...the Fang. this is the page... http://www.devicemanuals.com/downloadguide.php this is the actual download address... http://www.audiovox.com/manuals/owners/1286364A.pdf as i said there were several versions...but I'm certain you will find what you need here.Any other probs or ? shoot me a follow-up take care...the Fang.
Mar 22, 2009 | Audiovox MVDVD4 Car Video Player
Disc won't load and then shows weird symbol in right corner
Check the black spindle that holds the disk it may be cracked or broken or the little spring tabs are broken. If this is the problem when the disk spins it lifts up and the head doesn't read the disk, this is what has happened to mine. I am trying to locate the part but so far have not had luck finding it.
Sep 17, 2007 | Audiovox D1708 Portable DVD Player
Audiovox MVDVD4 Car Video Player Logo
871 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
