Question about JVC AV-27230 27" TV
JVC TV AV27D305
Picture too dark even with brightness turned up to high. Very poor picture quality.
  • zuzim Mar 03, 2008
    Thanks for your suggestion. Our JVC is only 3 years old but reading of other people having the same problem as we are and taking a chance on getting it fixed and a maybe 50 percent success rate of it staying fixed, we have decided to shop around for a new TV. Life is too short to worry about it.
    Brigadier General:
  • 6,966 Answers
Assuming the CRT is still OK, it could either be:
1. Screen Voltage is low;
2. G2 B+ is out (common problem is a mega ohm resistor open);
3. a resistor gone high (or open) in the DA converter of the controller IC circuitry.
Any of the above would require extensive knowledge of electronic circuitry and components, use of a DVM and a soldering iron. Perhaps your best bet may be to seek the services of a professional.
Pls likewise consider the age of the TV (if a couple of years) and/or the downtime and cost of repair,. it may be more practical to purchase a replacement unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 03, 2008
  • Louie  Role
    Louie Role Mar 03, 2008
    couldn't agree more, so here's to enjoying it to the fullest.
    Cheers.
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Mar 23, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV27320 Screen too dark
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Oct 12, 2006 | JVC AV-27230 27" TV
JVC AV-27230 27" TV Logo
113 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
