Question about Dryers
Dryer drum not working
I have a dryer where everything is working, but the drum does not turn
  • paul_cheryl Mar 04, 2008
    belt seems fine and tension is good
  • paul_cheryl Mar 09, 2008
    tried doing that first and it does not turn at all.
    This is a frigidaire dryer, model GLEQ0215EEO, serial XD63718070
The elememt comes on and gets hot >I can here the timer makinig a slight noise but the drum won't run.
Posted on Feb 18, 2009
    President:
  • 1,314 Answers
You need to check the belt if you hear the motor running
Posted on Mar 02, 2008
  • robert samples Mar 04, 2008
    try turning the drum by hand and whats the brand and model num
  • robert samples Mar 09, 2008
    sounds like the rear bearing is locked up on the drum they have a kit to replace that or something is stuck in the door glides either way you need to pull the drum
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Dryers
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Maytag Centennial only 18 months old - out of warranty. - When motor engaged drum does not start turning - as if the drum is jammed and motor is whining (attempting to run) - open dryer , rotate...
heatman101
Apr 14, 2011 | Dryers
Dryer drum won't turn everything else works including motor, belt seems OK
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 20, 2010 | Dryers
Hotpoint vtd 20 drum is not turning,everything
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 11, 2010 | Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
The dryer drum won't turn. Everything else seems
If you can hear the motor running when it is turned on then you dryer needs a new belt. If you cannot hear the motor running it needs a new motor.
Apr 11, 2009 | Kenmore Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
Marvin
Marvin
