Question about Durabrand 5.1 Surround Sound Computer Speakers
Durabrand Surround Sound Right Front No Output
I've had my Durabrand surround sound for a couple years now and have had no problems. Now, for some reason I can't get any output from the front right speaker....the speaker works fine when plugged into another connector, but the right front isn't working. Any suggestions?
Nevermind....I feel like an idiot, but I had the balance all the way to the left on the media program on my computer....
Posted on Mar 03, 2008
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
Need help hooking up my duraband surround system to my tv and dvd,tv has 1 set of holes in front and dvd player has in and out
plug the dvd audio into the amp and video to the tv if you have an output on your tv plug it in too.the amp. plug cable in back of tv
Jun 24, 2009 | Durabrand 5.1 Surround Sound Computer...
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Need to know how to make the surround sound work through regular T.V. with durabrand surround HT-3915
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
Jerry G.
Feb 22, 2009 | Durabrand HT-3915 System
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Durabrand 5.1 Surround Sound Computer Speakers Logo
156 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
