Sony KDSR50XBR1 50" Projection HDTV Logo
Anonymous Posted on Feb 27, 2010
RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
I need the codes to get into the menu to reset lamp hours..THANKS
  • 1 more comment
  • Anonymous Feb 27, 2010
    Sorry, I need to check the hours, not reset the hours, do you have the codes so I can do it from the remote commander..THANK YOU
    Thanks for the PDF file user guide for the TV
    Thanks, it wont let me get to the lamp time, but I got into the menu. I guess I will figure it out. Thanks again
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Feb 27, 2010
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783155
Points
6681
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
  • Jaime Hernandez Feb 27, 2010
    Try the following instructions from the image below:
How to replace lamp sony sxrd projection tv model no. KDS-55A2020
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Lamp burned out after 3 hours use, 2nd one.
only Original lamp is durable,
Original lamp USD100
Have a nice day!
Jerry
Lampdeng Limited
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
I have an SXRD KDS-R50XBR1. Just replaced the lamp and now the red led is blinking 6 times, anyone know what the problem may be. Sony support was no help
6 Blinks is a over temp problem. one the thermal senser is defective also Sony will not work with a Generic Lamp, Must be a Sony Lamp only.
1helpful
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
I JUST REPLACE MY LAMP IN MY SONY KDS-55A2000 HOW DO I RESET THE LAMP HOURS..TV IS STILL READING PROJECTION LAMP NEARING LIFE END
you need to go into the TV's menu and select replace projection lamp menu and follow the on screen instructions to verify and reset the lamp timer, (its in your instruction manual , in detail) , i am awaiting a new phillips bulb for mine, as i always use the original enclosure, no need for extra plastic, and its easy to complete the swap, and reset hours via TV menu
2helpful
Just lost the picture and now the lamp light is flashing
If lamp light on Sony TV front start flashing that means Lamp is dead and need to be replaced.
Lamp replacement is easy and procedure would be written in user manual of TV.
2helpful
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Not finding what you are looking for?
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
