Question about Dishwashers
Miele Dishwasher Problem
I have a Miele Icognito G658 SCVi, and the drain/intake light is on. I have followed the instructions in the Manual and it not going off. Help needed.
  • 1 more comment
  • rosie34 Aug 01, 2008
    Same problem. Drain/intake light was on. Did all the things book said to clean filters. Called service dept. went through their instructions. Nothing changed. Told service call would be $175 just to enter my house plus cost of part. I was told that the motor had burned out because part of the propellar blade was broken. Since nothing went past the fillters I can't understand what could have broken the propellar blade. So the motor was replaced at a cost of $289.65 add to $175.00 service call. The bill with taxes came to $504.96. What I can't understand is how could the motor look so corroded, what could have gotten past the filters to damage the motor. I'm wondering if it isn't a manufacturer's defect. Any case the part cost seems excessive when added to the service call which only less than an hour.
  • sdlight Aug 17, 2008
    I have same dishwasher and same problem, I've cleaned out all filters, arms, checked all connections, etc. and still doesn't work. I think problem might be related to the electronics. Past experience with electronic dishwashers tells me there is a way to reset the control pushing a combination of the button controls, but there is no advice on this in the operating instructions. Any advice would be appreciated....Thanks a million!
  • Anonymous Feb 04, 2009
    hi everyone,
    i assume that if you are reading this Short message you are probably in the same "what the hell"situation as I used to be.
    the red light came up, cabin full of dirty water, 30min to clean this mess up and still the red light.
    I think i have been lucky, I switched the dishwasher off for one hour,then switched back on and now it's working properly. hope your situation is gonna end like mine.
This just happened to me (my hands are still dripping from cleaning out the water at the bottom of the tub). Frustrated because I had cleaned the filters, bailed out the water with a cup, yet the light was still flashing. I finally followed the troubleshooting guide in the operating manual and held down the start/stop button for 5 seconds, while the machine was on, which seemed to reset everything. Works fine now.
Posted on Sep 03, 2009
There is a small panel, behind the toe plate. You need to remove two screws, and the 5 inch metal plate comes off. Inside this there is a reservoir, that when it fills up with water, trips a float/switch. the float swithc is suposed to trigger the water pump to drain the reservoir. Then, the machine must dry out so the electronics un-trip themselves. You will see when you remove the plate. What I did was manually dry the reservoir with paper towels - this seems to fix the issue - problem is, where is the water coming from?????
Posted on Dec 12, 2009
This happened to me and I noticed there was about 4 inches of dirty water that hadn't drained from the dishwasher. I took out all of the water, cleaned the filters and then started the dishwasher again. It worked. Good Luck.
Posted on Jul 10, 2008
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
I have a Miele Built-In Icognito 658/850 SCVi. The intake/drain light is on, and I have followed the directions in the manual. The light turns off after I follow the directions and the unit turns on but...
Check to see if the water shut-off valve (located under the sink, it is an electromagnet valve, located at the pipe's entrance to the machine) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Mar 02, 2008 | Dishwashers
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Miele dishwasher will not drain (G 2270 SCVI)
you need to replace the non return valve.
May 27, 2012 | Miele Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
We've got an Meile Incognito dishwasher, model G 843 SCVi plus. It purges at the begining of the cycle and then seems to fill with water, but then the red Intake/Drain light starts to flash and the cycle...
I would start by checking the drain line where it is connected to the garbage disposal. Check and make sure there is no solid build up obstructing the discharge into the garbage disposal. You can go a step further by removing the dishwasher drain line for thorough check up
If it has been establish that there is no obstruction by other means. There may be a problem with the control board.
I would suggest cautious approach in making rush decision on replacing the board.
Here is a link to the manual
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G843%20Vi-SCVi.pdf
Aug 02, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Icognito G683 SCVI Plus. Residual water seems to be standing under the base guard and lots of moisture remains in the dishwasher?
Many dishwashers intentionally leave a bit of water in them to keep the seals from drying out...
if there is more there now then ther used to be then check this out...
Dishwasher Problems - Water will not drain out
heatman101
Jan 21, 2011 | Miele 24 in. Incognito G863 SCVi Built-In...
WATER BUILD UP UNDERNEATH DISHWASHER WHERE MOTOR IS AND SENSOR THINKS IT IS FLOODED HOW DO i REMOVE THE WATER
Water under the dishwasher could be from a leaking hose or loose hose connection. Check these by removing the bottom front panel. Also chec the seals for the heating element, door, main tub,float. You need to run the dishwasher at least every other day or the seals can dry out
Sep 21, 2010 | Miele Incognito G658 SCVi Built-in...
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Miele dish washer
I have a miele G 643 SCVI Ingognito the re-0cccurring prob is the the drain/intake light comes on quite frequently I have to cylcle the on/off switch twice to clear the fault. I have check the drain line several time w/o any obvious findings what's next
Feb 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
1,659 people viewed this question
Top Dishwashers Experts
