Question about Hotpoint RB787 Electric Kitchen Range
Hotpoint rb787 My lower heating element won't work so we replaced that but still doesn't work. I had a service tech come out and says the mother board and relay need to be replaced--at $245! Does this sound right? The entire range is going for $5-600....
  • elena2270 Mar 03, 2008
    Would it make a difference if the stove top works and the broiler works?
  • shan_keller Oct 01, 2008
    I have this same problem; but, I haven't talked to a repair tech yet. I
    have managed to check the wires from the eoc to the element and I find
    no resistance so the wires are probably good. The clock still works.
    President:
  • 1,314 Answers
Before i replaced that i would check all the connections and the power comming in to the range about all of the electronic ranges now days will give a fault code of f1 if the eoc is bad
Posted on Mar 02, 2008
  • robert samples Mar 03, 2008
    they are all on separate circuits it could be a bad reley in the eoc but most of the time nothing will work and the clock will show f1 code id check the wires from the eoc to the element before i replaced it
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
My oven preheats then when it reaches temp....it beeps F2 after a short period of time and seems to stop heating....even after reseting it...can you help. I have replaced the bottom element and the main...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Dec 02, 2010 | Hotpoint RB787 Electric Kitchen Range
How do I remove the bottom heating element?
Kill all power to the stove because the element is wired directly to the element. Then remove the element. nothing to it.
Aug 07, 2010 | Hotpoint RB787 Electric Kitchen Range
I have a RB797W,oven not heating
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 26, 2010 | Hotpoint RB787 Electric Kitchen Range
On my Hotpoint RB787 range, how can I prevent my broiler element from being on any time the oven has been turned on?
There is no adjustment. When set to bake, BOTH elements are supposed to heat. On broil, only the top heats. To answer your question, you can't..........
Mar 31, 2010 | Hotpoint RB526 Electric Kitchen Range
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
Replaced heating element in oven but still remains on.
When the bake element shorted out, did the element make a big bang and perhaps even short against the metal bottom of your oven? I am suspecting the relay on your electronic oven control shorted and fused together. With this in mind, unplug the oven and gain access to the electronic control. Now trace the wire going from the electronic control to your lower bake element. Once you have figured which one it is, remove it from the electronic control. Tape it off with black electrical tape and plug the oven back in. At this pint, the element should not come on. Dis it come on or is it off. If off, replacing the electronic contro is the next step or if handly enough, you can replace the relay on the control...Let me know if I can help further.....
Eric Campion
Feb 14, 2009 | Hotpoint RB787 Electric Kitchen Range
Element burnt out
replace the swich for that burner.thats the one behind the knob.
Dec 02, 2008 | Hotpoint RB787 Electric Kitchen Range
Hotpoint RB787 Electric Kitchen Range Logo
204 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
