Question about Video Game Consoles & Games
I cant connect to internet to play xbox live. i have a 5-port hub fast etehernet 10/100 and on my box it continues to say ip address failed
  • 85 Answers
Just check the program,, or maybe the files are corrupt,,
Posted on Mar 03, 2008
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
Xbox can't find network on PC.
the other persons tip is trash mines better ;)
you can go to your routers2_bing.gif website and enter it manually. Type this might be it or try or
when it shows your routers2_bing.gif info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just if it doesn't give you two. the gateway2_bing.gif is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address2_bing.gif so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is you can use i use but you may not have the 2 in yours.
a website that'll help
list of ports you have to open
any other ?'s email me at
Nov 19, 2009 | Computers & Internet
Xbox Live connection problem
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as:; Subnet mask as:
and Default Gateway as:
2. Assign Primary DNS Address as: and Secondary DNS
Address as:
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Apr 13, 2009 | Zyxel Prestige 334 Router
Cant connect to xbox live
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be
If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply it would sugest a cabling problem.
However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Apr 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox live
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.RICHARDM69
Sep 08, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Ip address for xbox live
ok, firstly i hate these problems.
first things first, switch your hub off (leave for 2 mins) switch back on, this may refresh the ip address, also switch your xbox off.. then try agian.
Get back to me and let me know what happens from here.
oh also are you connecting your xbox to the pc? or directly to your broadband hub? if you can connect it directly to your hub, this should solve any problems
Aug 07, 2008 | Microsoft Xbox 360 Elite Console
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Change NAT to open
I don't have your Internet connection details or OS
so we'll start from the beginning:
1.Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your time zone. On step 3 this is important; select your Internet connection type. On the 4th step leave the Address Mode in Dynamic and enter the username and password supplied to you.
Once you have configured your Router to work with your Internet connection type, you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here and follow the instructions. Something you should keep in mind which isn't mentioned on this page is, for each port you forward under the box that says "IP Address", don’t put the IP address of your computer, you put in the new IP address of the Xbox 360 which was one of the 5 that was generated from that link in step 2. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start> run> type in ‘cmd’ then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Feb 23, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Linksys 5-port Workgroup Hub
Hi Tman,
Here is a link to the Xbox ports.
In the firewall option, direct those ports to the IP of your Xbox. I don't have an xbox, but I would think there is someway to set a static IP on it. That way DHCP won't change your xbox ip when you reboot it. Some routers allow you to assign a specific IP to the xbox, but not sure about yours.
Visit this site, It may have your router, and will tell you how to setup the ports for your xbox step by step.
Jan 06, 2008 | Linksys EtherFast Cable/DSL Router
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
