It might be the av cable that is causing your PS 2 console to be playing in black and white. I would try and use the standard av cable hookups for your PS 2 and see if it makes a difference. If it is still in black and white then it could be there is something internally wrong with your PS 2 console.
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
Turn on your Wii console and set your television to the input select being used.
If you are seeing the image from the Wii in black and white, try the following to get the image in color:
Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
An on screen menu option. This is often accessed by using the "Menu" button on the remote.
A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Picture Is Black and White or Does Not Appear Situation:
The console powers on and shows a black and white image on the television screen The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used. AV Cables Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To) Try another set of inputs on the TV, or hooking the Wii console up to another TV. If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To) Component Cables Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To) Try another set of inputs on the TV, or hooking the Wii console up to another TV.
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Situation:
What to do:
AV Cables
Component Cables
Still Not Resolved:
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Situation:
What to do:
AV Cables
Component Cables
Still Not Resolved:
I am guessing that you mistakenly plugged your Wii console cables into a component input section, rather than the normal AV or AV2 input. You can easily tell this by finding out which input station you have to select with your TV remote. If it is component 1 or 2 then your problem you plugged the cords into the wrong section. If you notice in the picture that the component are red, green, and blue, and the AV are red, white, and yellow. The Wii hook up cable is made for the Red, White, and Yellow. Just use a flash light and make sure you are plugging them into the right spot.
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
