Question about Sony Playstation 3 (PS3) Console
Ps3 dns error
I connected my ps3 to the internet with ethernet cable took me a wile to do it but i managed to do it but bout month later i just stoped connecting and i have no idea why can you help
  • alanppp Mar 03, 2008
    i connected my ps3 to the internet with ethernet cable took me a wile to do it but i managed to do it but bout month later i just stoped connecting and i have no idea why can you help
    Problem Solver:
  • 5 Answers
Try unplugging your modem and router and then plug them back in. This will refresh your settings. May work.
Posted on Mar 03, 2008
Need help getting online with 80gb ps3 using ethernet cable.
Try going to the settings, then network settings, and then go to internet connection test, and then push yes when prompted. If there is an error still then maybe your connected wrong or you need to call your internet provider and let them know what is going on. They will walk through it with you.
Nov 12, 2009 | Sony Playstation 3 (PS3) Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Same problem as everyone else :"DNS error and some numbers"
Go to internet settings and manual set up then try these dns settings.
primary dns 4.2.2.2
secondary dns 4.2.2.1
~I find i dont always need to use the secondary one.
hope this helps :)
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
DNS Problem On PS3
try setting up your network in auto.
go to internet connection setting an select easy, it should setup itself.
May 02, 2009 | Sony Playstation 3 (PS3) Console
Connects but no internet connection being allowed through.
You should configure your Router as a "router" or as a bridge. Usually, you can access the router's IP via web service (using http://ip.address.of-this.router). In this web access, you can modify your router configuration to act as router or bridge, also you have to specify the DNS, DHCP configuration as well.
Maybe with posting your Type of router, i could help you more with it...
Mar 09, 2009 | Zyxel Prestige 334 Router
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
When i try to hook up the ps3 to the internet it finds the IP but when it says connecting to the internet it won't connect it says that it is a DNS error? but i do not have any ethernet cables hooked up to...
check your pc they will be there Winxp users go to Control panel open network connections then open local area connection click on properties scroll down to Internet protocol (TCP/IP) hightlight it and click properties, your dns settings should be there!
Or Contact your service provider for the DNS settings!
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wireless internet connection wont work!
Ok, sometimes consoles dont like to be on the same network as other devices so it causes Ip and DNS conflicts. You just need to play around with the settings till it works.
Jun 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 internet connection problem
if wireless you have got to go to the router and un plug the ethernet cables and the power cable then plug them back in then it works i have had this problem
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
