Question about HP PSC 2410 All-In-One InkJet Printer
Message: Remove and check print cartridges
Replaced both color and blak ink and display screen shows check and remove cartridges. Tried unplugging and turning off, but does not help. Computer does not promp to select realignment as manual says.
  • Anonymous Mar 12, 2008
    After replacing the tri-color cartridge, the printer worked for about ten pages and then keeps reporting, "Remove and check cartridge in right stall" even after it having checked and re-installed the cartridge.
  • Anonymous Mar 27, 2014
    will not copy from the glass on top of the unit, it was printing but won't copy, says to realign but that doesn't work
    Novelist:
  • 188 Answers
Hi Natalia,
Please click on the web link given below and perform the steps as provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054461&cc=us&lc=en&dlc=en&product=303753
Perform the steps carefully.
Have a great day!
Posted on Mar 28, 2008
This helped. Thanks. I ended up c hanging the black cartridge and all was fine then.
Posted on Jun 17, 2008
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Hp officejet 5510 remove and check black cartridge message and i replaced the black to new one.
Hi Shaharz !
As per the information you have provided, I understand that you are receiving an error "Remove and check black ink cartridge" on the All-In-One display screen. If yes, perform the below steps.
Let me provide you the cause of the issue. The most cause of the issue is that if you are using refilled, re manufacture ink cartridges, cartridge is not fitting properly, wrong cartridge no. However, perform the below steps to resolve the issue.
1. Remove the print cartridges from the printer.
2. Clean the print cartridges using the lint free cloth both the cartridges heads as well as inside the printer.
3.Follow the steps below to power cycle your all-in-one:
a. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
b. Wait 30 seconds.
c. Plug in the power cable to All-in-One and also to wall outlet.
4. Insert only the black ink cartridge first and check the message on the printer.
If the issue is with the black ink cartridge then the same message will be appears on the printer. If not it will prompt you to insert the color ink cartridge.
Do the same procedure with the color ink cartridge.
If the issue persist, then it shows that the issue is with the black ink cartridge. check the expiry date of the print cartridges and try to replace it.
I believe the issue is with the printer itself. However, the printer using the HP 56 and 57 ink cartridges.
As you have mentioned that you have already replaced the black ink cartridge. Then it confirms that the issue is with the printer. However, you can try resetting of the printer to its default settings and check for the issue.
To reset the printer, perform the below steps.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
The printer might be turned off after performing the above steps, so no need to worry about that.
Then turn on the printer and check for the result.
Hope this will helps you a lot!!!
With Regards
Mike.
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    "remove and check cartridge" error message
    http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
    I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
    The color cartridge appeared to be the issue. It had been in for months and used infrequently.
    May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    HP G85 All says remove and check color cartridge and prints only green/blue color
    This is a known issue on this machine. What I do is open the printer as if replacing the cartridge and allow the cartridge holder to move to the exchange position. Then I unplug the power cable from the back and close the printer again. Keeping your finger on the power button, plug in the power cable again. Keep the button pressed for about 10 seconds, allowing the error flag to reset. Switch on again and wait for the initialise to finsh. It sometimes takes another 5 minutes for the message to disappear but it should go eventually.
    Mar 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
    "printer error - check paper" after cartridge replacement
    First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
    Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
    Check ink cartridge error reading won't go away and can't use it.
    Switch off the machine. depress all three buttons with the button depressed switch on the machine and hold the button in for a few seconds. Did the problem go away? No? try www.fixyourownprinter.com
    Jul 01, 2007 | HP PSC 2175 All-In-One InkJet Printer
    Printer Cartridges
    Since this is an all-in-one. It could be any of the following: A software glitch since these are software driven. Check HP for updates. A clogged nozzle on the cartridge- try cleaning the cartridge print nozzle with a foam tip swap or coffee filter soaked with ink jet cleaner or 90% isopropyl alcohol. Try a different cartridge. Try cleaning the contacts. Try using the HP image zone software. Go to Setup, Tools, and Clean print cartridge. Worst case scenario bad flex cable or board.
    Jan 26, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
    HP PSC 2410 All-In-One InkJet Printer Logo
    2,325 people viewed this question
    Seeker5211
    Seeker5211
