Question about JVC GR-D30U Camcorder
Condensation operation posed
After few minutes of recording I get the message "please wait condensation operation paused,please help me
  • mariv May 05, 2008
    I have same problem on my jvc minidv gr d30U. When I try to open it shows the message "condensation operation paused", "please wait". What should I do?
  • werpt May 26, 2008
    camera reads"operation paused-condensation"
    Novelist:
  • 153 Answers
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Posted on May 26, 2008
How do i get rid of message code 3 ??????
Actucally, there are a few ways to bypass Cinavia, but no program can remove Cinavia. If your video is a homemade movie or other personal recording, to play your recording without muting you may either:
· Pause the video, wait 30 seconds for the audio to be un-muted, then skip over those portions where the professionally produced material is used and continue playing the rest of the video, or
· Pause the video, wait 30 seconds for the audio to be un-muted, then play video from a different optical disc for at least 10 minutes before continuing playback of this video.
Mar 05, 2015 | Sony Playstation 3 (PS3) Console
When trying to record or replay, I'm getting an error message that says "Please wait - Condensation, Operation Paused." I've waited now over a week & still getting the same error...
Put the camcorder in a warm dry place for a few hours, there is moisture inside the unit, that triggers the humidity sensor and shuts the camera off. If after drying the camcorder for a reasonable time it still will not function you will need to get it repaired.
Mar 03, 2011 | JVC GR-D90U Camcorder
I have a error saying please wait condensation operation paused what does this mean
It probably means that a moisture sensor has tripped inside the recording mechanism. Did you take the camera from a cold (i.e air-conditioned) place into a warm place?
Generally waiting 'til the camera has warmed up and whatever moisture inside has gone away will let you use the camera again.
Jun 19, 2010 | JVC Digital Video Camera
Condensation operation paused
Remove power from the camera. I remove the battery as well. In the back of where the tapes go, on the left side is a silver component. It's just behind a metal roller that hangs down from a plastic piece over the head. If you look behind the roller diagonally across where the tape goes, you can see a black square on the right side of the silver component. Clean this (gently!) with a moist cotton swab. The swap should get a bit of black gunk off. I'd recommend cleaning it with a dry swab next to remove any moisture. Wait a minute or so to be sure it's dry. Then re-apply power. You should not see a false condensation message for a long time.
Mar 13, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Please Wait Condensation, Operation Paused
This is often referred to as DEW and is a sensor inside the camera that detects moisture. You can hasten the removal most times by warming the camera with a hairdryer on medium setting and not too close to the plastic case. When you store the camera store it with a few of those little bags of silicone crystals that come in many packages that we just throw away.
Please rate our help to keep the service online
Aug 21, 2009 | JVC Video Cameras
I found instructions with pictures on fixing this problem online at
http://www.freewebs.com/ltooz/03jvcgrd70u.htm
The process involves taking the camera apart.
Other forums I have looked at have mentioned waiting the error out or allowing the camera to air out.
Jan 12, 2009 | JVC GR-D22U Camcorder
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Please wait -Condensation operation Paused
Feb 02, 2008 | JVC GR-D31EK Mini DV Digital Camcorder
Gr-dx97 - condensation, operation paused message on screen
Dec 31, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
JVC GR-D30U Camcorder Logo
263 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
