Imperial IFS40 Deep Fryer
Problem for Imperial IFS40 Deep Fryer
When i turn on the poilet it turn on the frier it reach to temp then turn of every thing
By parey on Mar 02, 2008
ifs-40
Best Solution
posted on May 06, 2008
Helpful)
AbsoluteServ
Rank: Guru
Rating: 90%, 51 votes
If the main burners ignite with the thermostat off, you could have a bad t-stat or a bad gas valve. If the gas valve is a combination safety, (all built into one), check your wiring connections.
If I have the symptom right, you should call a professional.
Was this helpful?
Yes
No
Popular Solutions for Imperial IFS40 Deep Fryer
Questions and Unsolved Problems for Imperial IFS40 Deep Fryer
Do you recommend Imperial IFS40 Deep Fryer?
Answer
Answer
fyer temp. will not regulate when turning thermo. nob
Answer
Hello I need to replace on/off switch of my fryer IFS40, where can I get parts of it?
Answer
main burner will not light pilot is ok and on.
Answer
I have an Imperial 10 burner/dual oven stove; model IN-10R. My oven pilots will not light with the... (More)
Answer
deep fryer won't stay lit, replaced thermocuple didn't help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Imperial IFS40 Deep Fryer:
Top Deep Fryer Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Deep Fryer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
