Speaker Selector Have a Sirius music system in place a 80watt amp with 12 speakers hooked to it thru out my house. All the speakers are hooked in series. In my family room are 2 of the 12 speakers. Would like to play my Plasma TV thru those 2 spkrs in the family room and still have the ability to switch them back to play the music. Can a speaker selector switch be used if so how can I install it?
ongolo
  • 11 Answers
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Posted on Mar 19, 2007
SOURCE: Bose Wave Radio/CD - Sound from only one speaker
had the same problem with the speakers, I am now just using one channel power both speakers, Its not gone on fire yet, not and ideal solution, one channel was driving me mad, and this is free option
Posted on Mar 02, 2008
SOURCE: M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
Go to www.allelectronicsrepair.com , he repaired mine and it works fine now
Posted on Mar 20, 2008
  • 151 Answers
SOURCE: Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Posted on Jun 04, 2008
SOURCE: M&S DMC1 master... sound unexistant
check your power supply module
Posted on Jul 20, 2009
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
Not outputting to all speakers from CD, but does from DVD
Hi,.
With the indulgence of the others...
If I understand your problem right:
1. CD works only in Speaker A (but not in Speaker B);
2. DVD works on either or both A/B;
3. CD will work if plug into to VCR input but selector must be of another source (not VCR).
A couple of suggestions:
a. pls try doing again the reset as ginko has suggested but make it a bit longer, i.e. unplug it from the mains for a couple of hours;
b. since you have remove most of the wiring, why dont you try switch A & B. make the family room speakers the B while the speaker selector the A;
c. hook the CD (only) using the RCA cables (red/white) nothing else;
d. play any CD music and go through the paces of selecting source, speakers, surround/hall/theater/etc as troylove11 has suggested.
This would be now a simple setup, 1 source (CD) to 1 output/speaker (the family room) via the Denon. Try different settings. If the CD plays normally then, without changing any setting nor powering it off (but with volume level all the way down), remove the family room speaker wiring and replace it with the wires to/from the speaker selector.
the idea is to determine which is the real issue, the Sony, the Denon settings/hardware or the speaker selector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 15, 2008 | Denon AVR-3801 Receiver
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
Purchased 2 used sonance sonamp 260 for homewide speaker system (12 pair).line out from receiver into first amp powering first 8 pair.line out from first amp into second amp powers remaining 4pair.only...
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Nov 04, 2009 | Sonance Sonamp 260 MKII 2-Channel...
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Add more speaker to dvd player/s-air suround sond system
I have revisted this question and I *think* you are talking about a "speaker selector". A speaker selector is a unit that prevents an amp or receiver from going into safe mode or shutting down.
Follow this link:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-224
Mar 31, 2009 | Yamaha RX-V463 Receiver
No Sound
Make sure you plug into the GREEN speaker port on the PC.If using a digital connection,try going back to analog.The difference is almost non-existent,and much less hassle.
Oct 21, 2007 | Creative Labs I-Trigue 2.1 3300 Computer...
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
 Grubhead
Grubhead
