When I scan an exesting document through my printer into PDF Master I can not type in the blank lines that I need too fill in.
    Novelist:
    Scholar:
  • 136 Answers
Not sure if pdf master allows this functionality...but it may..you should consider upgrading adobe reader to allow this function to work.. www.adobe.com and downld the latest adobe reader.
also when you scan you need to specify that you want to take the fill in options.
only works on printed documents not hand written ones.
try paperport much better product.
Posted on Mar 03, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
No pdf format on scanner file type
You can scan document to multi-page TIFF file anf then use a TIFF to PDF Converter to convert all pages from the TIFF document to PDF file.
Jan 21, 2013 | Canon Pixma MP480 All-In-One InkJet...
HP DJ F2235 doesn't have PDF option to scan PDF
Scan to PDF requires third-party software and linking that software to the HP Solution Center. The HP imaging software only saves to BMP, DCX, FPX, GIF, JPG, PCD, PCX, and TIF. You need a program like PaperPort or save the document as an image and then convert it to a PDF (using Microsoft Office, another Office Suite, or a dedicated image to PDF conversion program.)
I wish that I had better news for you. PaperPort can be found for $50 from some vendors after rebate.
May 30, 2012 | HP DESKJET PRINTER, HP OR COMPATIBLE
When I scan a document, I don't seem to have the option of saving it in PDF file format.
This maybe so, as PDF is a proprietary service, and the scanner doesn't support it? have you all the drivers and software installed? anyway, what you need to do, is scan whatever it is, in as a document or a picture whatever, and then process if with a PDF converter. Check out the master search link below and simply choose one download and install, then import the scan into the PDF converter and convert. There are also some programs that will scan PDF a Google search should turn them up?
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=pdf+converter
Oct 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
HOW I PUT PDF IN MY SACANER
hello,
When you want to scan using the scanning software choose to save in pdf.
Or configure the scanning to save to pdf.
Hope it helps. .
Sep 12, 2009 | Sharp AL-1551CS Printer
How do I scan a document into a pdf and send by email
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr21
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I want to scan a form and save it, and be able to fill in the blanks later. I can save it as a pdf document, but can't edit it.
When you scan it, the original manufacurer's software should allow you to save it as a Word document or some other editable format. PDF, JPG, TIF, and other image formats probably won't work.
Jan 26, 2009 | Computers & Internet
Scanner
seems to me you havent inserted the paper to the scanner correctly, i have f380 right next to me and never had such a problem.
Apr 01, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
