Question about Intel Desktop Board D845EPIL Motherboard
It won't turn on
I have got everything in in the right places an all
and theres a lil green LED that has come on so im guessing thats a good sign and i have changed the power supply and still it just not seems to do anything when i push the power button, you got anything i can try to fix it ?
thanks
    Sergeant:
    Champion:
  • 250 Answers
Reset your bios by removing the battery on the moutherboard and disconnecting the power cord from the back of the pc. If three is a jumper you can short to rese the bios (check our manual) do that too after you have removed the battery and power cord. Let it sit for a bit and then come back, put the jumper back in it's original possition, put the battery back in and the power cable.
Newer motherboards detect a power supply change.
Posted on Mar 02, 2008
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
Why wont my ps3 turn on
The problem might have to do with a power thing maybe the power switch i mean maybe the power at your home went down and that causes the PS3 to basically be unusable, what i would recomend is to go and make a diagnostic to your playstation, im not sure where but im sure that if you google it you might find cheap places to see whats wrong with your ps3Good luck!! :D
Nov 29, 2011 | Sony Playstation 3 (PS3) Console
Hi I have a LG 42' plasma, but it wont turn on. it does have power but just flashes the on-led green three times then goes back to red. I can here a relay click but not much else. Im guessing it could...
You are on the right track, Hopefully if you have some bad caps hope that they are obvious because you can have bad caps that look as good as a brand new one.
Sep 09, 2017 | Televison & Video
Washer won't start
From your comment 'washer won't start' I am assuming that there is no power indication i.e. no lights/LED's?
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 09, 2011 | Washing Machines
Myall m 06211-2 48.4Q901.021 from an Acer Aspire 9300-5713 (its a motherboard) Problem: placing power adapter into MB turns system LED's on and can power off with a/c but on restart the orange (charging)...
I am not computer literate but I have noticed if you hold down the switch that turns the screen off when lid closed you cannot power off by the on off button. Worth a try anyway. Good Luck!
Mar 30, 2011 | Acer Computers & Internet
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Mar 12, 2010 | 1992 Ford Probe
1998 honda civic cuts out at lights but starts back up right away - whats going on?
is there check engine sign on ? if so go to the right hand side of the dash and pull a lil blue plug from a dummy green socket only has two wires use a lil wire to complete circuit the check engine sigh will begin to flash a code one short flash is 1 and one long flash is 10 example long long long short short short is 33 if there is more than one code a new series of numbers will begin and start all over automatically most likely its you idle air control valve dealer only part dont buy used 99%of time there burned out good luck
Jun 24, 2009 | 1998 Honda Civic
Dell Precision 340 Minitower Power issue
Fauza
Hi
First things first:
1) You just change the power on button for other, on Radio Shack they have it.
2) cables that came from the motherboard to the ON/OFF SW. you have to soldering with the new Power Button, thats it. very easy task! you can use any power botton to fix this.
good luck
Feb 08, 2008 | Dell Precision 360n PC Desktop
Amp
Sisnce you didn't mention the protection LED, I'll assume it's not on.
You need to measure the voltage across the B+ and ground terminals of the amplifier to confirm that the voltage at the terminals is least 11 volts. Also check the voltage on the remote turn-on terminal. Place the black meter lead on the ground terminal of the amp and set the meter to DC volts.
Nov 07, 2007 | Power Acoustik LT-980/2 Car Audio...
Intel Desktop Board D845EPIL Motherboard Logo
194 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
