Question about Pioneer XV-HTD520 Multi-disc DVD Player
NO POWER NEED HELP
WONT POWER ON. ITS STUCK ON THE TIMER BUTTON JUST BLINKING
  • mhenegar Jan 28, 2009
    No power - timer light blinks
  • gallsy Feb 02, 2009
    i have exactley the same problem please help
I picked one up from the garbage dump and it had the same problem. When I opened it up I found out that it did not have A/C voltage from the transformers secondary but it had voltage on the primary.
Looking at the primary side of the transformer it has 3 pins, first pin has a white wire, second pin (center) has the transformer windings and the third pin has a orange wire. I may have the colors backwards but it does'nt matter. Between the center pin and the pin on the right there is a 2Amp fuse down inside the plastic part of the transformer.REMEBER TO UNPLUG FROM MAINS FIRST !!! Unplug the transformers primary side connector from the power board and use a meter set to OHM's or diode and check continuity between the center pin and the right pin. If there is no continuity then the fuse is blown. Unsolder the wire on the right pin and solder it to the center pin. You have just bypassed the fuse. It should work now.REMEBER TO UNPLUG FROM MAINS FIRST !!!
Now it would be nice if I had a remote.
Posted on Mar 21, 2009
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
While watching tv I touch something on the remote to make the tv go into "on timer" The red light is blinking. I have removed power then on again the remote and tv controls work but after 4...
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
Jan 04, 2011 | JVC AV-27920 27" TV
My wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Nov 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
We have a ge air conditioner and we just plugged it in for the summer and it wont turn on when you push the power button it starts blinking ES and wont turn on
On our a/c the remote button was stuck, not allowing any others either on the remote or the unit itself to work. Once my wife discovered which one was stuck, every button started working again.
Jun 25, 2009 | GE AJCQ08ACB Air Conditioner
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Green timer light
check the number of blinks each blink means something
Apr 19, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Pioneer XV-HTD520 Multi-disc DVD Player Logo
261 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
