Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Lower loop broke- do I have to start from step one?
As I was changing colors, by tying the new to the old and running it through, my lower loop thread broke. I have never actually threaded my machine but it looked easy enough with the color coded diagram- so I tried, but it is not looping right. Do I have to undo everything and start from step one?
I see this has been answered, but hopefully this will help someone else. It is NOT necessary to rethread the whole machine. You can just pull out the two needle threads, rethread the lower looper from where is is broken, and rethread the needles in the proper order.
Hope that helps
Posted on Nov 15, 2012
  • White Sewing Master
  • 1,388 Answers
The thing is that the needle thread is picked up by the lower looper, and if the looper thread breaks and the needle thread is still hooked up, you are trapping the needle threads under the looper thread, so it cannot sew !
You can use tweezers to pull the needle threads off the looper, then thread looper, or just start over commencing from right to left.....Lower, upper, needle, needle.
Posted on May 29, 2008
Yes, take all threads out, and re=thread according to the diagram, following the threading order.
Posted on Mar 28, 2008
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
On the lower loop blue keeps breaking
Looper thread breakage occurs frequently when the thread path is incorrect or threaded out of order. Most machine must thread the upper looper first, then the lower looper. The lower looper thread ends "draped over" the upper looper in the last step before being pulled toward the back of the machine and under the presser foot.
Another common cause is tension that is too tight.
VERIFY the thread path is correct for every thread!!!! Missing a thread guide or looping around a guide will throw your machine for a "loop."
Another hint, when threading, ALWAYS RAISE the presser foot throughout the process and be sure to give each thread an "extra little tug" when going through the tension to make sure it is seated completely. Sometimes, the thread will even "pop" when it seats. When a thread break, checks that the thread has not "jumped" out of a thread guide or the tension disk.
If the thread breaks, it is usually less frustrating (in the long run) if you remove ALL the thread and start over from the beginning. Trying to snake a broken thread out of order through the sequence is frequently 99% UNsuccessful!!! It takes a lot of familiarity with your machine to be successful threading out of order, but there is still a lot of room for failure!!!
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH
Make It Handmade How to Thread Your Serger Out of Order
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
Nov 17, 2016 | Sewing Machines
The serger will not form the initial chain. Have checked threading and have new needles, any ideas?
It's an odd thing but on my serger, it actually matters the order in which I thread it. I *try* to tie the new thread to the old and pull it through rather than re-threading, but when I've had to re-thread, I've had trouble getting it to loop again when I thread left to right. It seems that the loopers only loop if the right looper is threaded before the left.
Apr 16, 2015 | Sewing Machines
I have a brand new Juki MO-50e and the threads are loose on the back of the fabric, how do I fix this?
  1. . re-thread your machine with a rainbow of colors. (important that you remove the existing threads if you are not sure it is threaded properly.) make sure you are lifting the presser foot while rethreading.
  2. Sew a good 6 inches.
  3. Look to see which threads are the offenders and tighten the co-responding tension knobs a little.
  4. Sew another 6 inches. Examine the result. Adjust tension again if needed.
  5. Work this way until you have the stitch balanced.
  6. Finally when your stitches are perfect. clip the threads at the spools in back. And tie on the coordinating colored thread for your fabric.
Get used to this procedure since it is common to have to adjust tensions when you change fabric. Good luck!
Oct 23, 2014 | Juki MO-644D Mechanical Sewing Machine
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
The thread on my juki 816-dd4. How do I retread
Here you go Angie: look on page 6 of this pdf. I recommend that you print this, put it in a zip lock bag and tape it to the underside of your table.
http://www.raichert.com/adobe/MO804-12-16%20Inst.pdf
Basically Any serger is threaded like this.
Upper looper, Lower Looper and then needles from left to right. Any time you break a thread you have to start from the beginning taking the thread out and starting over.
If you want to change colors. Clip the threads near the spools, change out the color and tie the thread to the previous color... gently pull through the thread path to the needles. Clip the knot and thread the needle.
Jul 30, 2012 | Juki Sewing Machines
My needles hits the lower loop on my 16sh644 serger and the thread from my needles won't stay wrapped around the lower loop lever
it's very possible that the machine is out of time & needs to be serviced at a sewing machine shop
May 26, 2012 | Singer 14SH654
I have tried several steps to correct my Bernina 160's bottom thread tension; too loose. I did occur after I cleaned out bobbin case & hook race,
Buy to loose do you mean big loops on the botom? If so fallow these steps.
Usaly big loops on the botom of the fabric means that the top is not threaded coreccty. I would sugest threading the top thread again all the way to the needle. After you have done that pull on the thread and lift and lower the presser foot. There should be tension when it is down and no tensoin when it is up. I allway do this before I sew on a machine. If you do not have tension on it when the presser foot is down you did not get ithe thread in the tension unit. If you have tension when it is up then your machine needs a upper tension release adjustement.
Hope this helps friend.
Other problems could be a small peace of broke needle it the race area(inspect this close).
If you adjusted your bobbin tension this may need to be reset.
Mar 17, 2011 | Bernina Virtuosa 160
Hello I just got a new home My Lock 334D machine. It has Seized intermittenly. could we troubleshoot the problem & fix it together?
Un-thread and then see if the machine will run without thread.
If not, it needs to go into the shop for repair.
If it does, refer to the manual. Or, the guide that should be printed on the inside of the serger's door.
Raise the thread antenna to it's highest position. Keep it at this position when serging. If lowered for storage, and threaded, be sure the thread does not tangle around the antenna arms.
Raise the presser foot.
Open/set the tensions to zero.
Raise the loopers to their highest level - there may be an indicator mark on the side of the serger to match with a mark on the handwheel to help with this.
Start threading from the right to the left; upper looper first.
After threading, reset the tensions to a medium number, lower the presser foot and stitch a chain to test the stitching.
Serge a scrap and adjust the tension as necessary.
Once you get the serger working as it should - don't run out of thread. Tie off, open the tension, raise presser foot and gently guide the new thread through the threading process.
When changing the thread or removing the thread to store the serger, cut the thread at the antenna, leaving thread tails for tying off the new thread.
If you do not have Nancy Zieman's "Serge with Confidence", you will find it much more informative than the average serger manual.
May 01, 2010 | Sewing Machines
How to i thread my 008d bernina serger?
I believe it is color coded right?
start with the Upper looper follow from the upper looper throught the loops below the machine up through the tension disk and to the place where the thread cone sits. now retrace your steps from the thread to the looper place thread under foot.
by starting from the finishing point to the starting point you know where you are going with the thread when you thread the machine so upper looper lower looper right needle left needle. you must get it exactly correct or it wont work
Jun 21, 2009 | Bernina 1008
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
261 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
