Question about Dishwashers
Dishlex dishwasher global 300
It went through the cycle then just keeps pumping with the eco button flashing, even when the door is open. I have tried switching it off and on with no success, please help. Audrey
  • rova Mar 04, 2008
    Hi in reading other solotions we tilted the dishwasher and water came out then on restarting it was fine, thanks very much Rova
  • Anonymous Mar 06, 2008
    Dishlex 300 Global circulating motor continues to run after completion of wash cycle .It can only be stopped by turning off at wall switch.
    Any ideas welcome
    Sergeant:
  • 351 Answers
Its in flood mode you need to get into the base and soak up the water from the flood switch (front middle),then it will restart,but you may have a leak or just dirt buildup under the lower door seal
Posted on Mar 03, 2008
Dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
May 22, 2011 | Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global 300. ECO light flashing.
if that fails then try emptying the over flow try found behind the kick panel below the door. 2 phillips screws will be found either side under plastic screw covers, behind kick panel you will find the cover for all internals remove a total of 6 screws from these covers, then with a torch you will see the internal workings of the machine. located at the bottom of it all is a small kidney shaped tray that may have some/alot of water. this is the over flow tray. empty by soaking up the liquid with a sponge. reassemble then try starting it.
Jan 16, 2009 | Dishwashers
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Dishwashers Logo
367 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
