Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Installation code tv set top box
Freeview
  • 4 more comments
  • brunorobbo Jul 26, 2008
    instalation code required for sagem freeview box
  • wellington osbert Jul 28, 2008
    Please, help me with the installation code for SAGEM ITD59G freeview box.
    Also, help me to return to the original manufacturers set code.
    Thanks.
    Endy
  • kingagard Oct 05, 2008
    cant remember original code,everytime i try it says bad code try again,help
  • mickareid Oct 13, 2008
    Me too. Have lost most of my chgannels and don't have the 4-digit istallation code to help me retrieve them. Can you tell me how I might discover my code or re-set it.
    Cheers
  • afcbuck Oct 18, 2008
    I have lost the 4 number setup code for my Sagem IT58 freeview receiver can you help???
  • Anonymous Nov 15, 2008
    Need installation code for sagum freeview box....please please help!!!
Try 1 2 3 4 universal settings works with mine
Posted on Feb 27, 2009
  • 3 Answers
1, 2, 3, 4
Posted on Jul 09, 2009
Require a installation code for sagem set-top box
Posted on Jul 06, 2008
TRY 1234 or 0000
anyone got a manual for one of these?? i've lost mine.
Posted on Jan 06, 2009
2 Suggested Answers
  • 105 Answers
SOURCE: code for wharfedale dv823b
The codes come from your all-in-one remote control manufacturer. Check the manual or download a code from your remote manufacturer's site.
There may not be a code. Some remotes have a "guess" mode where you simply press "code", point the remote at the device, then scroll up or down using the "channel" button until the unit powers on or off. The remote will memorize the code after you select which device on the remote itself you wish to marry that code to.
Posted on Mar 28, 2008
One for all remote to work on technika freeview box and polaroid tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily........
http://electro-medical.blogspot.com/
May 28, 2016 | One For All URC-3445 Remote Control
Alba set top digital freeview box
normally its - press menu - install - scan for channels and then save
something similar to this
hope it helps davetech
Aug 08, 2014 | Alba DVBT set top box
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Set top box installation
RF is the normal round coax cable in black.
Further you need to select your video channel on TV to watch the set top box RF signal. Usually you change the RF channel frequency also on these things. If you don't know channel number let TV scan it.
Apr 18, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
1,726 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
