Oasis elite washer lid locking mechanism broken
Accidently the lid got pulled open as macchine was running and a little plastic piece that holds the lid locked in lace broke off, now the lid will not stay locked and the washer will not run. is there a way i can replace that plastic contraption that holds the lid locked? please help, thanx....
  • 1 more comment
  • Anonymous Jun 16, 2008
    The same thing happened to me. Once I obtain the part myself is it easy to replace or do I need to get a service rep to come out and fix it?
  • Anonymous Mar 17, 2014
    whirlpool washer lid is open lock is engaged and I can't close the lid to run the washer
  • Anonymous Mar 24, 2014
    Lid door not locking
Go to repairclinic.com to find the part. Have the make and model ready, and you have a good chance of finding the part there.
Posted on Mar 02, 2008
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Door won't lock on top loading kenmore elite oasis washing machine
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Ok.. so I have already posted a question about my Kenmore elite oasis washer.. It was showing a dl error code, which I found out was a lidlock error... after looking at the lock closely, I see that they...
a replacement part should be sought and installed, you can bypass the switch, but the switch is there for a reason if you bypass it the spin cycle will not stop when opening the lid and injury to children or others can happen so this is not recommended
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis is making a loud banging noise during spin cycle. Also just noticed a small amount of water under the washer. All other cycles appear to be working fine.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis Elite HE washer. I keep
Sep 11, 2009 | Kenmore Washing Machines
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
423 people viewed this question
Top Washing Machines Experts
