Question about Konica Minolta DiMAGE A2 Digital Camera
Electronic Viewfinder problem
I have a Konica Minolta Dimage A2. Recently I lost use of the electronic viewfinder. I can still view from the rear display screen. The viewfinder remains black whether I adjust the switch on the back of the camera to automatic, or dedicated to the EVF. I have also checked the menu settings and it is set correctly for both the screen and EVF. Any suggestions of retrieving use of the electronic viewfinder---I miss it!
t00nz
  • 4738 Answers
SOURCE: minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Posted on Nov 17, 2007
SOURCE: konica minolta dimage a1
Sounds like a CCD fault. Many A1 users, including myself, have had this. Allegedly, Sony, who made and fitted the CCD sensors, had a manufacturing "issue" at the time. Many A1s were recalled and others, including mine, have been successfully repaired free of charge by Sony on request. I suggest that you contact your vendor or a local repair shop to discover whether this service is (still?) available in your location. It's well worth the effort as this is a fine camera. Good luck.
Posted on Jun 07, 2008
  • 4 Answers
SOURCE: konica minolta dimage z6 problem
My mode switch also failed. As an electronics tech (retired), I was able to source the proper part, and replace it. The camera is perfect again. I have more of those switches in stock.
Posted on Sep 21, 2008
Obertelli
  • 3006 Answers
SOURCE: Need rubber eye cup for Konica Minolta A2 viewfinder.
These are frequently lost and are fashioned of purest unobtanium.
When mine disappeared I bought a non-working A2 on eBay very cheaply and carefully removed the old eyecup from it and glued it onto mine, it also had the benefit of providing spare body covers, a lens hood, battery and a strap. A cheaper alternative is to buy a non-original replacement, see item number 220440673814 on eBay, or search for seller birthdayboy; the eyecups he sells are good, but it looks ugly and gets in the way as it isn't flush with the back of the camera.
Don't re-sell the donor camera if you buy one: sooner or later you'll need the flexible circuit board from inside it, as the one in your camera WILL eventually fail to power the viewfinder lcd backlight. The old camera will serve to show you how to dismantle and repair your original one. It's one of those jobs which is so fiddly and time-consuming that a professional repair is totally uneconomic.
Posted on Jun 23, 2009
Obertelli
  • 3006 Answers
SOURCE: I own a Dimage A2 and the viewfinder is very
In short, no. Spares are generally no longer available and expensive when they are.
But there are huge numbers of broken A1's and A2's which sell for near-nothing on auction websites which may be purchases as spares donors. The viewfinder lenses on both models are identical, although the actual electronic EVF display is different. Ask the right questions and buy wisely and you'll also end up with spare batteries and all the body covers which might have been lost from yours for no extra cost.
Posted on Feb 11, 2010
Testimonial: "Thanks for that"
I bought a used Konica Minolta DiMage A2 online. Is it normal for the image to change from color to black and white, then back to color, repeatedly, in the viewfinder and screen when preparing to make a...
When it goes to black&white the lightconditions are probably too dark. It has a better range in black&white so it switches. (but if I remember correctly this only happens when you're in video-modus 'cause in photo-modus the flash will pop up)
Sep 29, 2011 | Konica Minolta DiMAGE A2 Digital Camera
I own a Dimage A2 and the viewfinder is very scratched. Can I buy one from anywhere?
Jan 18, 2010 | Konica Minolta DiMAGE A2 Digital Camera
I have Konika Minolta Dimage A2 after swich on the view on the screen start shakeing for a few secunds ??
This indicates that the flexible circuit board (flexi pcb) to the LCD has started to crack. usually it happens to the viewfinder LCD first.
Unfortunately it happens to almost all Dimage A1's and A2's eventually and cannot be fixed unless the flexi pcb is replaced. New ones are no longer available and are very difficult to fit due to the extensive disassembly required. If you can get one, you'll find that the weaknesses were never resolved and it's just as prone to failure as the old one. A good used replacement A2 will cost less than any repairs, but is equally prone to the same fate.
All you can do to prevent it getting worse is to never flip out the LCD panel and you should also use double sided foam tape to stick the viewfinder permanently in the down position. Konica Minolta definitely knew of the weakness as they remedied it with a different design in the later A200.
Unfortunately my A2 failed just after I bought three extra batteries and a battery grip for it and the replacement A2 failed a month after purchase. It's a superb camera but seems to have been made to ensure that it doesn't last.
I hope that you've found my answer to be of use and that you can prevent your problem from getting worse. All I ask in return is that you take a moment to rate my answer.
Oct 27, 2009 | Cameras
Jun 11, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Looking for camera parts.
Apr 19, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Viewfinder on Minolta Z1 Dimage doesn't work
I had the same problem. I got it to work by adjusting the viewfinder focus back and forth, this is the little nob to the left of the viewfinder. Might work for you?
Nov 29, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Konica minolta dimage z6 problem
Sony handle repairs to Konica Minolta gear (I think) good luck.
Feb 10, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Black screen cannot take picture minolta dimage a1
i have seen a recall notice on this camera - you can send it sony konica minolta for free repair.
search web for details.
Oct 22, 2007 | Minolta DIMAGE DIGITAL CAMERA MODEL Z 1...
Viewfinder
Please check the rotary switch on the camera is in the correct position. The viewfinder and monitor settings are very close together! You can download the manual from the link below: http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z10/D_Z10_E.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
"Milky" Viewfinder
After a quick look at the manual you can find in the setup menu 3 "reset defaults" which shoud set you camera back to its first settings.
Sep 13, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
88 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
