WONT POWER ON
ITS WONT POWER ON. THE TIMER BUTTON JUST BLINKS AND THATS IT.
PLEASE HELP
  • 2 more comments
  • mudman680 Aug 30, 2008
    i have a pioneer home theater model xv-htd520dvd/cd reciever
    it wont power on stuck on stand by
  • nycwoman1 Nov 17, 2008
    I have the same problem. Sony DAV-C990 will not power on. At first it had a red flashing light. Now will not power on at all. Anyone know why this might happen and if this is an easy fix?
  • Anonymous Dec 03, 2008
    SAME PROBLEM
  • tube tech Dec 10, 2008
    Power Button shows red light , wont turn on
    Scholar:
  • 48 Answers
Which type of home theate sys is it ?
a brand or describe the speaker set up.
could be a voltage problem to turn on the amp too.
Posted on Mar 08, 2008
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Hd1080 power wont com on green lite that says timer blinks wen u plug it in but wont turn on
Thats usually caused by failed capacitors on the DM power board. REplaceing them will usually fix the issue. You can get the DM repair kit for your model at www.tvrepairworld.com which contains the upgraded caps and the CD with repair instructions.
Apr 29, 2011 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Sony KP-51WS510 no power
try unpluging the power board thats got the power button & 3 led lights on it then use the remote to power on
it worked for me
Sep 14, 2008 | Televison & Video
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Timer light flashing
The capacitors wont always show any outward signs of being bad. But it the LED blinks constantly without stopping thats telling you the DM isnt completeing the boot sequence. So most likely the capacitors are bad. But dont put the same ratings back. go with 1000ufs @25V but make certain they are the 105 degree celcius capacitors. If you need further assistance let me know
Jun 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
Magnavox big screen will not power on button blinks but wont turn on
Need model number really, but sounds like a bad SSB module(small signal board). It would have to be replaced and depending on the model they can be expensive.
Sep 06, 2007 | Televison & Video
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
196 people viewed this question
 Grubhead
Grubhead
