Question about Garmin Rino 530 GPS Receiver
GPS Coordinates I have not be able to figure out how to enter the lat and long coordinates on my Rino. I am not even sure I can but would think I should be able to, thanks for any help.
Looks like if you go to mark a waypoint for your current location you can then edit the long and lat to whatever you want it to be...
Posted on May 23, 2008
How do I program my lowrance to locate reefs if I have the lat log reference?
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
Aug 10, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Gps coordinates
yes go to new way points put in lon and lat.click enter
Sep 28, 2013 | Boating
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
Dec 10, 2011 | Garmin eTrex Venture Cx 2.1 in. Handheld...
Entering coordinates
When you press on your Where to? graphic a menu will come up that will give you a number of choices including
Address, Go Home, Points Of Interest, and 3 others. There should be an arrow point down in the lower right corner of the screen. When you press that the screen will scroll down a page and you should then see the Coordinates Globe. Press this and the screen should change to the Enter Coordinates screen. This will allow you to enter two sets of coordinates for your destination.
May 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
Unable to load coordinates for a projected waypoint
There are two ways you can load a way point.
1. Hit mark on your GPS. Push up on your rocker until the coordinates are highlighted. Once they are hit enter. From here you can change the coordinates to what ever you want.
2. If you have the software (Mapsource Trip & Waypoint Manager) you can enter the waypoint by going to "Edit" then "New Waypoint" or hit Ctrl + W as a shortcut. Once you create all the points you need, plug in your GPS and turn it on, then click "Send to Device"
Make sure that your mapsource and GPS are both setup on the same datum and lat/lon style corrdinates as well or it could throw it off.
Jan 20, 2009 | Garmin GPSMAP 60CS GPS Receiver
How do i insert a negative (-) deg co-ordinate into my nuvi 200
Positive Lat Lon coordinates are for the eastern and northern hemispheres respectively. If you have a negative coordinate, they indicate a location in the western or southern hemisphere.
To enter a Latitude coordinate of, for example, -31 degrees, you would enter 31 degrees, but specify S (for South) rather than N (for North)
Negative Lon coordinates would use W (for West) instead of E (for East)
Jan 08, 2009 | Garmin Nuvi 660 GPS Receiver
Latitude longitude
Create and save a waypoint for any location then update that waypoint with the lat/long you were given (just click on the lat/long and key in the new coordinates).
Apr 17, 2008 | Garmin eTrex Legend GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Jul 17, 2007 | Garmin 60 GPS Receiver
Garmin Rino 530 GPS Receiver Logo
235 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
