Question about Dell 1450 (D1450U) Wireless Adapter
How to use Dell 1450 Wireless Adapter
How to scan and connect using this model adapter the utility window itself is not opening
any suggestion
  • 121 Answers
Not being funny but have you switched it on
Posted on Mar 03, 2008
Add driver for window 7
Microsoft Windows Vista and Windows 7 does not include native drivers for the Del True Mobile 1450 USB Wireless adapter and there will be no 1450 USB Wireless adapter drivers available from Dell that are compatible with the Windows Vista or Winds 7 Operating System.
There will be no support for the Dell True Mobile 1450 USB Wireless adapter in Windows Vista or Windows 7.
For 1450 USB Wireless adapter drivers for Windows XP 32bit Click Here.
Sep 15, 2012 | Dell 1450 (D1450U) Wireless Adapter
My main computer is vista, the one with wireless router , but I want to use my xp computer with the dell 1450 wireless usb adapter. it won't work
Dell do not provide support for vista on the 1450 USB adapter - see here http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&l=en&s=bsdv&dl=false&docid=20075A1DBD60D650E0401E0A55175C46&doclang=en
I have not tried this - but found on another forum http://www.vistaforums.com/Forum/Topic5380-21-1.aspx olution:
  1. 1) Install the Dell 1450 USB drivers on a PC with XP32 (assuming your target machine is 32-bit)
  2. 2) Copy the "2K" drivers from the install directory ( c:\program files\dell wireless ) to a flash drive.
  3. 3) Copy the "2K" drivers from the flash drive to the Vista machine. After you plug in your 1450 choose to manually select the driver then browse to that folder. You should be up an running in a few seconds.
The extra connection manager software that came with the adapter won't run on Vista but you'll still get a good wireless connection.
Apr 13, 2010 | Dell 1450 (D1450U) Wireless Adapter
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
Dell 1450 Wireless Adapter ProblDell wireless
This driver works with 32-bit Vista and Windows 7
http://members.driverguide.com/driver/detail.php?driverid=1556056
Aug 21, 2009 | Dell 1450 (D1450U) Wireless Adapter
Were I can get driver for dell wireless model D1450U usb adaptor for my optiplex 745
You can get a driver for your adapter here.
If you want the Dell Wireless Utility get this too.
Jun 25, 2009 | Dell 1450 (D1450U) Wireless Adapter
Dell wireless 1450 wireless USB adapter DRIVER for Vista?
Here are the drivers for windows XP They will make your 1450 work
If you have Windows Vista check out this Link
Jun 23, 2009 | Dell 1450 (D1450U) Wireless Adapter
Dell wireless 1450 usb adapter
lol, I've had the same problem and I too racked my brains. I suggest a linksys adapter, thats what I did and it worked out fine. P.S maybe its just not compatible
I hope this helps.
Aug 28, 2008 | Dell 1450 (D1450U) Wireless Adapter
Dell Wireless 2350 BroadBand Router
You may get some benefit from downloading and installing Netstumbler
This util will allow you to scan the channels and select a chanel with less devices on it. then change the broadcast channel in the wifi router. This may reduce interference in the connection.
Also cordless phones are notorious for interfering with wifi routers so put some distance between the router and the base if you can.
Another option is to get an external antenna for the router to boost signal strength
something like THIS or THIS and place up high on a shelf. Just check your router antenna is the sort that comes off... should unscrew. not all do unfortunately so be careful not to break yours!!
BTW - the router is not a bad unit but it also is not the best around either REVIEW
Jul 19, 2008 | Belkin 802.11b Wireless Notebook Network...
Dell 1450 (D1450U) Wireless Adapter Logo
139 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
