Question about Philips 60P8342 60" Rear Projection Television
I have a problem
I have a Philips 60ph8342, The tv won't turn on. I opened up the rear panel and saw three fuses, I tried switching them around and the TV turned on for a second and shut off.Any ideas what I could do to fix this problem?
  • 3 more comments
  • Spytech Mar 03, 2008
    Thanks for the response! Chassis # PTV916
    No! The TV won't come on at all. I opened up the rear panel and blew the dust off thinking that will help,But it didn't.
    The fuse itself says 250V, numbers stamped on board next to fuses are 1000, 1004, 1300, I cant tell if there blown. The fuses are made in white frost glass, There are three of them!
  • Spytech Mar 05, 2008
    This is spytech, I replaced the fuses and the TV turned on but quickly shut off. It seems like something is shorting out the fuses. I tested the first fuse next to the plug,Ohm reading is 1 instead of 000.
  • conine25 Sep 04, 2008
    I have a 2003 model ptv916.. we had a storm and i think the power board was fried, the in no power at all, can you please find me a part number for ordering a new one ....thank you
  • Philips Master
  • 8,617 Answers
You have a power supply problem. What is the chassis number of your set? Let me know the chassis and I may be able to help you out.
Posted on Mar 02, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Mar 03, 2008
    The Tv is going into protective shutdown due to a power supply problem . Do you get an error code with the LED blinking 2 times then pausing a second then flashing again? If so that chassis is famous for the SSM board failing thats a small board on the right side of the set that plugs into a simm socket.
  • Sonny Berry
    Were any of the fuses blown? If so what were the number stamped on the board next to the fuse?
  • Sonny Berry
    you will need to check the fuses as by changing them a second one has blown thats why the set tried once but now will not. You will need an ohms meter to check them as well as check the other items later after we verify that the fuses are good or bad.
Trunk won,t open so I can get to boot to open mu gas tank
Have you checked the fuse panel for blown fuses? If not, check there first. If so, check to be sure all the wiring harnesses in and around the fuse panel are tight ans secure. If you're really in a pinch and you have rear folding seats you can crawl into the trunk that way.
Jul 24, 2013 | 2003 Audi TT
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
My Philips 50PFP5332D 50 in makes this clicking sound when I try turning it on. The blue indicator light is on, but the tv won't turn on, it just continues to make this clicking sound for one hour or...
its the capacitor inside the tv open it up and you should see atleast 1 capacitor which has bulged ( looks like glue coming out of it ) usually a 3000 ~ you can replace these yourself no problem for around 10p each but i do warn you there is a chance you could lose your built in freeview in doing so!
Oct 29, 2011 | Philips 50PFP5332D 50 in. Plasma...
How can i repair the speakers? how can i remove the panel in front?
  • Turn on the TV set, bring up the convergence menu and make sure the three colors--red, green and blue--converge and overlap at the cross in the center of the screen. This is needed to help converge the TV later. Turn off and unplug the TV.
  • 2
    Remove the front screen by popping off the bezel and pulling the three combined screens out. Place wide cellophane tape around the frame to prevent the three screens from separating. Lay the screen someplace where it won't be bent or scratched.
  • 3
    Remove the circuit board from the bottom of the CRT neck. It may be held in place by one screw or glued in place with silicon. Pull it out without twisting it.
  • Jan 09, 2011 | Philips 60PP9202 60" Rear Projection...
    My Phillips Tv keeps turning itself off after around a minute,the power button remians on and green but no picture or sound. It is like the fuse keeps tripping. If you unplug the tv and switch it back on...
    The main power supply is trying to fail. You might try giving us the model number since we can't guess exactly what kind of TV you have; LCD or plasma?? They suffer from some differing ills-
    Oct 23, 2009 | Philips Televison & Video
    Philips model 29pt3425-79 flat screen wont switch on
    May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
    Jun 01, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Front panel buttons on Philips rear projection do random things
    Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
    Pete....Digital TV & Radio in NC
    May 16, 2009 | Philips 55PP9401 55" Rear Projection...
    Big screen out of focus
    ok you have to open the tv intill you see the 3 bulbs and the big mirror
    the around each bulb is a wheel u have to turn that for the pic and focus
    Jul 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
    Philips 43PP8545
    You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
    Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
    Turning on SD-P403 Pioneer projection tv
    Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
    Oct 30, 2006 | Pioneer SD-P50A3Q 50" Rear Projection...
    Philips 60P8342 60" Rear Projection Television Logo
    125 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
