Question about Ovens
Door won't unlock after self clean
Used self clean - completed cycle
door will not unlock.
  • 1 more comment
  • ghstrawn Mar 02, 2008
    jenn air w2451w
    ran self clean - completed cycle
    door remained locked
    throwing breaker didn't help
    got door open - now won't close whole way
  • LucricaKenne Aug 24, 2008
    i have a ge cleaned it door will open but cant get the oven to come back on keep getting a mess.unlock door. i got it unpluged i reset
    it don't know what to do now
  • chimeme100 Jan 09, 2009
    Same issue would like to know how my expensive commercially built DCS products fail me more than my cheap Kenmore products in the past. Never again...
Jenn-Air Double oven wall unit older model no fault codes. First off I agree with all that say DO NOT set your oven in self clean for 3 hours...First off this is overkill and a waste of energy...second it cause all the electric and electronic components to take an overload of heat.
Fix on our after locked and even after turing power off... was to again turn power off remove face plate to the over (where all the knobs are) then find the locking solenoid and push back manually..Not liking 220 I still used a plastic long spoon to push back the locking device..That will be a savings of 200.00. Again DO Not use Self-Clean..
Posted on Oct 04, 2009
  • 125 Answers
Try turning the breaker off for a few minutes, If that doesn't work try restarting the self clean mode and canceling after it starts. If that fails list a brand and model number with the problem.
Posted on Mar 02, 2008
  • karen Oct 09, 2011
    turned breaker off / start self cleaning and turned it off and nothing works ???
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Tip
    How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
    Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
  • 4
  • Nov 18, 2012 | Ovens
    Door won't open after self cleaning and cool down has stopped.
    if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
    Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
    Cannot unlock oven door
  • Here it is!
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Oven door remains locked after completion of self clean cycle
    My oven door stays locked , when I press the clear button I get F1?
    I hold the clear button for a few seconds and still nothing.
    Please,
    Thank You
    Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Whirlpool RF367LXS Ceramic Glass Range not working
    Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
    Feb 02, 2008 | Ovens
    Ovens Logo
    278 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
