Question about GPS
I can not turn on my 530 and it dos not show that the battery is being charged on the screen
  • 5 more comments
  • Ryan Mar 03, 2008
    My unit is 2 years old. the problem is that i was updating the software a few months ago and while the unit was updating my computer shut off. now I can't turn on my gps unit and when i plug in the unit to charge it the battery meter on the screen dosen't appear. but the charger light is flashing. wanted to know if there was any way to reset the unit. or any other ideas? thanks
  • Ryan Mar 03, 2008
    by the way the gps unit is a garmin rino530
  • bmacbimmer Mar 18, 2008
    Charger light flashing on a Rino 530 gps and it will not turn on
  • Anonymous Mar 29, 2008
    THE GARMIN IS STUCK AND WILL NOT RESPOND. IT WILL NOT TURN ON OR OFF. STUCK ON.
  • Anonymous Jun 17, 2008
    gpsmap 492 will turn on but is stuck on intro screen. how do I get beyond this?
  • wmcd Jun 17, 2008
    gpsmap 492 unit will not turn on or off. stuck on intro screen
  • Kevin Miller May 11, 2010
    How old is this unit? How are you trying to charge it?
    Problem Solver:
  • 4 Answers
Well, holding down the right bottom corner of the screen definitely resets the unit but unfortunately, that's all it did. The unit stills powers up, then powers down. This is unit fully charged, don't understand.
Posted on Mar 31, 2008
  • 504 Answers
Yes, there is a way to reset it. You can try the reset button under the faceplate, or a Master Reset. Keep in mind, a Master Reset WILL ERASE ALL OF YOUR FAVORITES. In order to do a Master Reset the unit must be off. Press and hold the bottom right of the screen, then press the on button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts. To use the reset button, you must remove the faceplate carefully (put your fingernail or another object in the indentation on the top of the faceplate, and pull it toward you). Then press the reset button on the right hand side of the unit.
Posted on Mar 03, 2008
2 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Garmin 530 log on problems
Could be a problem with the memory card. Please try to remove that then power up and see if the issue is resolved. If not, it could be a problem with the internal circuitry. If this is the case, then unfortunately, there is no other go except to get the device service.
Posted on May 24, 2008
Irobot 530 won't start
have you tried reset, press spot and dock together
Dec 22, 2012 | iRobot Roomba 530 Robotic Vacuum
My laptop turns on, you can put in the password but it won't load and the blue screen comes on and then it restarts itself. It's a Samsung 530. Please HELP. Thank you!!!
i have had one of these myself... this pc suffers from various problems, mostly motherboard. Your specific problem has happened to a couple of friends, both filled their drives up so much that it "blue screened" We all know blue screen is often terminal. Your machine is getting on now. clear your drive up from DOS and windows ( delete unneeded files at start up, not through windows if possible.
Nov 21, 2012 | Samsung R530 Notebook
IT is a xxl 530 s tomtom. Do you keep the unit
While in drive view, tap the screen on the blue status bar, on the GPS signal strength. A new screen appears showing the battery charge level at the top right corner.
Dec 29, 2009 | Tomtom ONE XL GPS
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Installed wrong version bios on HP 530
u can try reseting the BIOS.onlyt option is taking out the CMOS battery and then putting it back but in tat case u hav to open up u r keyboard ,,its a bit risky,,so u better call up tech support for locationg the CMOS battery
May 14, 2009 | HP 530 Notebook PC
Garmin 530 hcx won't turn on
I think I fried the lithium ion battery by having it plugged into the charger and the computer, hopefully covered under warranty....
Dec 14, 2008 | Garmin Rino 530 GPS Receiver
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
GPS Logo
374 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
