Question about Whirlpool GEW9250 Electric Dryer
Whirlpool dryer the inside light works. The settings locked light on but no start.
    Scholar:
  • 52 Answers
Bad door switch? Bad start switch? Burner out thermistor?keever
Posted on Mar 02, 2008
Dryer GEW9250PWO control panel will not work or light up. Lamp inside dryer works. Also hold End Of Cycle button down and does lock panel...but still nothing other than that lights up. Any ideas?
Take a close look at the front LED panels, are some of the LED's lit up ever so slightly when this occurs? If so, it seems to be a very common problem with Whirlpool.
Nov 28, 2010 | Whirlpool GEW9250 Electric Dryer
Brand new Duet Dryer - WED9400SZ model - just installed and connected - everything looks good. BUT, it won't start. All I hear is a beep sound? any setting to be turned on?
Make sure that the door is firmly closed and the light inside the drum goes out. I have model YWED9400SW (brand new) that had the same problem. The spring lock on the top was not fully engaging. Press firmly on the top and bottom of the door until the light goes out then press start. Good luck.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I have a Whirlpool gas dryer LGQ7030K..the dryer does not turn on when start button is pushed.
If you open your dryer and the inside light isn't on - double check your breakers.
Also make sure the timer knob is set properly to a setting with minutes left.
Dec 06, 2009 | Whirlpool LGQ7030KQ Gas Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control panel
I was able to fix our problem by running through the control panel diagnostics as outlined in the repair manual, which I found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa?OpenDocument
All the diagnostic steps were successful and after I had worked through the list I was able to use the Automatic Cycles. Hope this helps!
May 27, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer
sometimes the control knobs that you set your dryer to different heating sets will go bad but it is in the control panel some where i whould say it is the heating setting
May 19, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
