Question about Denon AVR-2105 Receiver
Power Button Flashing Red
Unit kicked of and power button flashed red while watching/listening to Music DVD--admittedly at a high volume level. Allowed to cool down over night. Just tried powering up again (14 hours later)--power button shows green, appears to be starting up and then shuts off and begins flashing red. Happens every time. Please advise if you have any ideas short of contacting Denon tomorrow. Thanks.
  • 1 more comment
  • scollins121 Feb 27, 2009
    As soon as the unit powers up it kicks off then flashes a red ring of light around the stanby button. Is there any one else who has resolved this issue short of swapping tranistors?
  • imoda4 Mar 09, 2009
    I get flashing red button too.
    I was playing in surround mode at about 50% volume and a few blue sparks and a puff of smoke later and its all over. I was planning on having it repaired but after reading other comments it's seems it will be an ongoing problem. Ive got Aaron ATS 5 speakers by the way with the same low impedance.
    I had a Yamaha before and it never gave me any problem for years and years.
  • elco-fixer Apr 18, 2009
    Just managed to repair AVR2105 which had same symptoms as descibed above. Replaced a pair of output transistors and some o/c resistors etc. The only problem is the amp is generating too much heat. I guess quiescent current for output transistors needs adjusting, there is a trim pot near them and a socket to plug test wires I guess. Anyone knows how to adjust quiescent current and to what value?
    thanx
    Problem Solver:
  • 13 Answers
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
Speaker wires LOL wish it was that simple mate.
The real problem is denon now have their products made in third world countries and are no longer made in Japan.
They still charge top dollar for their products so, there is no excuse for them to have such lousy service policys.
I was scammed by denon for over $1200!
Not to mention the 3 times I had to unhook my complete home theatre system and the inconveinence of not having the amp as the central switching unit for several months.
I'm going back to YAMAHA, allthough I don't know about their customer service as in all the years I have owned YAMAHA products I have never had a problem.
Posted on Aug 03, 2008
Yep same thing happened to me three times!
Completely dead!
Twice under warranty and once out of warranty.
Denon Australia don't want to know about it and basicly said BAD LUCK !
FRANK from Audio Products Group ( Australian denon distributors) even admitted there was a problem with that (and other denon models) of a fault on the the power output stages and claimed my amp was fully upgraded on the second time in for repair and will not give the go ahead to have it repaired out of warranty
I argued that the original problem was never fixed but FRANK from denon Australia didn't want a bar of it so I suggest taking the shocking (bordering on criminal) after sales service into consideration when thinking of buying any denon products.
NEVER BUY A DENON FROM AUSTRALIA be warned.
Posted on Jul 19, 2008
Check to make sure the +/- speaker output wires aren't touching. I've had this problem before with frayed speaker wire strands poking out & intermittently shorting to the other polarity speaker output. This amazing receiver actually continued to play at low volume levels, but if I turned it up it would shut down similar to how you are reporting. I cleaned up the frayed wires & this fixed thr problem. Good luck
Posted on May 26, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Have a digital camera/mp3 player 44090/44091/44092/44093 have installed software but when we plug it in to usb slot doesnt register on comp. cannot transfer music etc. running windows vista please help...
I have fixed our problem! Hope this helps you out. I downloaded a manual for the 44090 model.
Make sure that you don't have it plugged into the usb port and the player is switched to mp3 mode. Open the software and then when it says to plug it in now, you need to turn the player into music mode. Press and hold for 3 to 4 seconds the centre power/play/pause button. It will start the red light flashing. Once the light is flashing it is in music mode. Plug in to the usb port and the computer should recognise it bringing up the install now button for the software. Click 'install now' and it should work.
I don't use the software to load songs I just use windows media player and once I had passed this install now bit media player recognised it instantly.
Everytime you want to listen to music you need to put the player into music mode by holding down that button till the red light flashes. Once music is loaded on it starts playing as soon as that red light starts flashing!
Good luck and I really hope this works out for you too.
Dec 15, 2008 | Audio Players & Recorders
Dec 14, 2008 | Denon AVR-1908
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Sep 03, 2007 | Denon AVR-2106 Receiver
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
Denon AVR-2105 Receiver Logo
2,054 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
