I have a RCA portable TV made for Radio Shack, (cat. # 16-3000), that has a broken flip down stand. I checked with Radio Shack and they had only some parts for this, but not the one I need. The stand flips down from the bottom of the unit and is replaceable. It was made in 2000. The only number on it, besides a serial number, is the Radio Shack cat. number. It is a 5" screen. The stand is needed to use it on a table top. Can you help me find this part? Thanks.
Comments:
Mar 04, 2008
- Ok, the serial # is 192896. However, I've located the tv on the above 'index to televisions'. After checking the original box I found,(on the bottom), the upc code with the number 160-3000 above it. The #16-3000 must be the Radio Shack cat # but without the zero. Then I checked every 5" tv on the list and it turned out to match the Memorex Portavision Television/Monitor #160-0125. This was confirmed when under the info for this tv it said 'Features/also: 160-3000'. The cat. no. for the stand is 10689768 and the part no. is HC-6532. Do I get this from Radio Shack or RCA?Mar 06, 2008
- Oh no. I thought that the list of parts for all those tvs meant they were available. That's why I accepted the answer. What is the secondary market, and how do I get a part from it?Mar 06, 2008
- Also, your previous message said RCA parts were available for this.
Mar 06, 2008
- Ok, I tried that and only found the parts list I have. Is there anything else I could try?Mar 06, 2008
- Ok, I tried calling Vance Baldwin Electronics and they had no record of part #HC6532 or the model # of the tv. There seems to be several differnent tvs that used this same part.
