Question about Canon PowerShot A60 Digital Camera
Goes off when switching
When I switch to the replaying mode, the green upper light is on but the image disappears and if I connect with the computer the message says that no camara was found. Taking pictures is OK.
I am having the exact same problem with my camera and computer right now, when a week ago I had no trouble getting photos onto the computer. I would love to know how to fix this!
Posted on May 09, 2008
Hi, How do you wire a Leviton switch to the next switch in a 4 gang box? Diagram? Thanks! Michael
Switches are not identified.
Single-pole switches are wired differently than 3-way.
Wire colors are not identified. Some boxes have red and black wires that carry power.
Add a comment and fill out details after studying image and reading information.
I am not there, so you can also add a comment and include in-focus photo of your switches that you posted on Flickr.
Following image shows single-pole switches, with typical black and white wires.
No bare copper ground wire is shown. Ground wires connect to green screw.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
So your new switch has 2 brass screws. No white wire connects to single-pole switch. One screw will have 1 black wire that goes to light fixture. The other screw will have 1 or 2 black wires that jumper or connect to the other switches as shown in image.
White wires are usually twisted together and covered with wire nut and pushed to back of box.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Leviton 15a 120v Sp Switch
When i turn my ds on it goes to the action replay before anything pops up it turns white even before datel shows up
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing up on the POWER switch.
    3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen.
    5. Tap the Options icon.
    6. Tap the Start-up Mode icon.
    7. Tap the top box for "M Manual Mode" and tap the "Confirm" rectangle.
    8. Wait for the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Mar 25, 2011 | Datel Action Replay for Nintendo DS
How do you connect the electric to wire bathroom lights on one switch, and the fan on the other switch, The power comes in through the switch, Both switches are located in the same box
In the box, connect all white wires together, that is the incoming power, the lights and the fan.
Then take the black supply wire and connect it to the bottom terminal of one of the switches and cut and install a jumper from that terminal to the bottom terminal of the other switch.
Next connect a black wire that goes to the light(s) to the top terminal of one of the switches. When this switch is turned on, power should flow from the supply thru the switch to the light.
Finally, connect another black wire that goes to the fan to the top terminal of the other switch. This will turn on the fan.
All ground or green wires connect together and the green terminal on each switch should have a piece of green wire to connect to all the other green ground wires.
Mar 16, 2011 | Dryers
The display disappears with in few seconds, though the power LED still green and the data cable is connected. If I switch of the power for few seconds (20sec) and switch on again then the dispalay remain...
Click on the link to find how to disable the sleep mode.
Disable sleep mode
Let me know if this fixes the problem.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 10, 2011 | HP L1908w Monitor
Acer A150-1049 Does not start up. Press On/Off switch > switch light goes on > drive, num, and caps lights flash momentarily, light 'whir' sound - cycling 2 to 3 seconds (drive?), nothing else...
If you don't see a POST/BIOS screen pop up then the issue is hardware based, the easiest way to get this resolved is to get it repaired or replaced under warranty, check your warranty here:
http://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information
if it is under warranty then you can go to the follow page to initiate a service request:
http://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
If the laptop is not under warranty, take it to a computer shop (you may end up having to pay a bit of money for the repair)
Oct 08, 2010 | Acer Aspire One A150-1049 Notebook
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
Jan 27, 2018 | Panasonic Viera TH-42PX80U Plasma TV
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Green Power LED is lit- But no image on the screen
Hi, I have just repaired one of these with the same problem. Turned out to be a 680uf 25v capacitor that had failed. Capacitor was visibly domed. Easy repair with new capacitor. Hope this helps.
Aug 10, 2008 | LG Flatron L1715S 17" LCD Monitor
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
Canon PowerShot A60 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
