LASKO model 5400 ceramic heater
The fan motor woun't come on but the ceramic plates still heat. The fan motor is function when indipendently hooked to a power source. There is a set of contacts just above the ceramic plates. When they are manually pushed togeter the unit operates fine. Is it safe to hard wire across the contacts and/or what is prohibiting them from automatically connecting?
  • Anonymous Mar 25, 2014
    the red light comes on but there is no fan or heat
    Sergeant:
  • 288 Answers
The contact are just a set of points. If you can remove them, file or sand, or whatever will do the job, a little on the place where the contacts touch. Usually that's all it takes. Make sure when the switch is turned on the lever/spring assembly moves and at least tries to make them touch. I don't really see a problem with directly wiring the fan. The only drawback is there is no real control except pulling the plug.
Posted on Mar 05, 2008
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
Fan in my heater not wprking
Replace the fan motor. It could also be the control board depending on the heater.
Nov 26, 2013 | Lasko 5132 Ceramic Compact Heater
I lost my owners manual & would like to know how to turn & operate my lasko ceramic heater. Thank you in advance. Roy Reyes
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Mar 15, 2011 | Lasko Ceramic Heater
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Hope this helped you.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
UI have a Lasko ceramic element heater with digital display, when the heater runs for a while, it will shut off, no display at all, I then have to unplug the unit for a couple hours to get it to function...
I do not know how to solve this problem but i will add my own solution. Like you said, you will have to wait for it to begin functioning again after you plug it back up.while its unplugged, you have to wait a moment until a small click it made.
Nov 26, 2010 | Lasko Ceramic Heater
Fan will not start its not frozen it turns free?
Check and see if you have power at the fan wires, if you do replace fan motor.
Feb 22, 2010 | Lasko 755320 Ceramic Electric Utility...
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
