Tv will not power up, it worked before I went to clean the screen
Tv went out after cleaning the screen, its a panasonic flat screen model# ct-32sc13g
  • jwilker Jun 15, 2008
    I Simply turned my same tv off and it will not power up again. is there a reset button? any other solution?
  • Anonymous Mar 18, 2014
    That's the color flat screen TV 32', model ct-32sc12g
    Genius:
  • 1,694 Answers
Liquid spill to front of PC board....pull chassis...clean with
alcohol and Q-tips.....blow dry with hair dryer..............T.
Posted on Mar 02, 2008
Panasonic CT-32SL14J green picture after blown fues replaced
no there may be loose contact or dry solder in circuit board attached to tube..ie video driver section ..resolder
all the solder joints cleanly...&also resolder the long ic ie
chroma ic...u can find where the problem is by gently tapping the main board or video board by a tooth brush
when tv is on. if the color changes by tapping u can get the loose contact..have a nice day
Mar 10, 2010 | Panasonic CT-32SL14 32" TV
I have a Panasonic TV Model#CT-35625B, How do I remove the closed caption?
It is in video options if is not present then video contains subtitles, to clean it is possible through options.
http://www.cellphones2009.bravehost.com/
Aug 08, 2009 | Panasonic CT-36D12D 36" TV
Power just quit had a great picture
panasonic tv's suffered from frame chip problems causing them to be stuck in stand by .not an expensive part though...
Apr 25, 2009 | Panasonic CT-32SL14 32" TV
Panasonic ct 32sl14 flat screen tv
Sorry no, it does not have the correct tuner, however you do not need a converter box if you are connected to cable or satellite
Jul 17, 2008 | Panasonic CT-32SL14 32" TV
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
Television has no power
check the fuse. The person i got mine from said it was dead. i took it home opened the back and the fuse is very obvious replaced it with a slo-blo fuse and its back to normal!
Dec 15, 2007 | Panasonic CT-32SL14 32" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
