Question about Wega Mininova EPU Espresso Machine
My bunn maker
It keeps flowing over over and it makes a mess and the grounds are all in the coffee and what can I do about it please. It has been doing this for some time. I did buy it sometime ago though. It is it worth fixing it and where do I get it fixed? Can I fix it if I order the oparts and where do I get the parts and which parts do I havwe to get. albertzimmerman@comcast.net thanks. again it is about 10 years old and thwey are expensive to say the least but we liked it.I would get an other one though
  • 189 Answers
What is the make and model of your brewer? If you will call 800-352-2866 with this information we can help you.
Posted on Jul 01, 2010
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
If i try to make more than 6 or 8 cups in my 10 cup bunn coffemaker. The coffee grounds overflow . This is a new coffee maker and we find a mess almost every time we make a pot. We have alwats used bunn...
This can occur with the use of finer ground coffee or use of soft water, filtered water, or bottled water. If you will call 800-352-2866 with the model and date code, we can send you a flow restrictor sprayhead which will alleviate this problem.
Jun 20, 2010 | Bunn 10 Cup Home Coffee Brewer
BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
May 17, 2010 | Bunn BT10B Coffee Maker
Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
May 08, 2010 | Bunn NHB Coffee Maker
Grounds in coffee. am using bunn coffee filters and still have a mess in my cup and in filter
Are you using a finer ground coffee? Or do you have a water softener, use filtered water or bottled water? If so, please call customer service to get a flow restrictor sprayhead which will eliminate this issue.
Dec 07, 2009 | Bunn NHB Coffee Maker
Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
Oct 05, 2009 | Bunn VPR Coffee Maker
Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Aug 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker
An overflow can occur when using certain kinds of coffee or the use of a water softener, bottled water, filtered water or reverse osmosis. If you will get the model and date code located on the bottom of the machine and contact customer service, a flow restrictor sprayhead can be sent out to you that will eliminate this problem.
Jun 05, 2009 | Bunn NHB Coffee Maker
Coffee grounds leaking out of the basket
When you are grinding your own beans or use certain types of coffee, you need to use a flow restrictor sprayhead. If you will contact customer service, a flow restrictor sprayhead can be sent out to you at no charge and this will eliminate the problem you are having.
Mar 03, 2009 | Bunn Thermal Carafe Coffee Brewer
Wega Mininova EPU Espresso Machine Logo
24 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
