Mac address filtering problem
I am setting up a router that i haven't used in a while. I don't have the computer that I used to set it up originally and MAC address filtering is on. How do I gain access to the router so I can add my new computer's MAC address or turn off MAC filtering?
  • a67994 May 11, 2010
    Which router do you have or do you know the MAC address for the
    old Computer?
  • 4 Answers
Reset the router to factory & re-configure it, you haven't been using it so you have nothing to lose!
Posted on Mar 06, 2008
2 Suggested Answers
SOURCE: mac address filtering problem
router has a reset button. of course!
Posted on Mar 04, 2008
I need to add a mac address to my router..so far not working
Open the setup page of the router and go to wireless tab. Click Wireless MAC filter sub tab. If wireless MAC filter is enabled then disable it. This option is always disabled by default. I think the wireless network might be the issue. If your wireless network is secured then make sure that you are entering the correct network key WEP / WPA .
Dec 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I'm trying to connect my router I need the ip address and password please
Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below.
    Accessing the router settings through a web browser.
  4. On this screen you should change the Router Name from its default value to something unique so that your Base Station will not be confused with another. Scroll to the bottom of the page and click Save Settings then click Continue when the Settings are successful dialog is displayed.
  5. Next, click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings and then Continue when the Settings are successful dialog is displayed.
  6. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  7. Next click on the Wireless MAC Filter subsection at the top of the page. Then Enable the Wireless MAC Filter option and select the option to Permit only PCs listed to access the wireless network. Click on the Save Settings button at the bottom of the Filter List window and then Continue.
  8. Now click on the Edit MAC Filter List button to pop up a new window (shown below) where you will enter the MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed. You may now close the Mac Address Filter List window.
    Creating a MAC Address Filter List will prevent unauthorized computers from using your connection.
  9. Finally click on the Administration tab at the top of the page. Change the default password for accessing your wireless router setup pages by typing a new one into the Router Password field and then confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed.
  10. If you encountered any problems during this configuration procedure, please consult the manual that was included with your router or contact the manufacturer.
  11. Your Linksys Wireless Router is now secure.
Sep 21, 2011 | Linksys Wireless-G WRT54G Router
How can i block my router TM-G5240 to other computers?? tks
one word "permissions"
you have to tell the router and the firewall that you don't want "abc" user to use the router.
this is done by logging into the router and allow/disallowing the user by MAC address ( Media Access Control) .
depending on the router to access it is going to a browser window and entering either 192.168.0.1 or
192.168.1.1
instruction set to secure your router is in the "helps" file.for
1.select the "Advance tab
2. select filter "MAC'
3. Enter name
4. under MAC address enter MAC address
5.on the DHCP Client select DHCP client from the pull down list; click Clone to copy that MAC address
Jul 23, 2011 | D-Link Tmobile Hotspot Tmg5240 Wireless...
I am trying to connect to internet the screen says erro code 51330
Hello val171156
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
Log into the router using the default IP (if you don´t know this, consult your router's manual for assistance). Locate the "wireless security" section of your router settings and find the WEP or WPA key.
If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
If you are using WPA, the Wii console is compatible with the following types:
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
3. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
The above steps usually resolve the problem. If the error message still comes up, there are other ways I can help you, but it would help if you could tell me the model number of your router, as some models have compatability problems with the Wii.
Hope this helps.
ajblaj
Sep 14, 2010 | Nintendo Wii Console
What is error code 51331?
Normal.dotm 0 0 1 253 1446 Statens bygningstekniske etat 12 2 1775 12.0 0 false 21 18 pkt 18 pkt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} Hello rb_singer
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
Hope this helps.
ajblaj
Sep 13, 2010 | Nintendo Wii Console
Error code 51330
Hello murz42
This error code is generated when the Wii console is unable to connect to the access point.
First of all, check that your router is compatible with the Wii www.nintendo.co.uk/NOE/en_GB/support/wii_support_5251_8071.html?id=8072
Are you using WEP or WPA security on your router? Log into your router using the default IP (if you don´t know this, or how to obtain it, consult your routers manual).
If you are using 64-bit encryption, the WEP key is a 10-character key consisting of numbers or the letters A - F. If you are using 128-bit encryption, it will consist of 26 characters. The WEP key must be hexadecimal. This means that it consists of the numbers 0-9, the letters A - F. It cannot consist of any special signs or letters. If you are using WPA, the Wii is compatible with the following types: - WPA - PSK (TKIP) - WPA - PSK (AES) - WPA2 - PSK (AES)
Next, check if your router is using MAC filtering. You still need to still be logged into your router. Find the section for MAC filtering, which is usually located under a "security" tab or something similar. If the MAC filtering is "on" or "enabled", enter the Wii´s MAC address to the list of approved MAC addresses. To find this, go to the Wii Channel menu, select "Wii settings" - "Internet" - "Console Settings". The MAC address is displayed on the first line.
Hope this helps. If you require any further help, please don´t hesitate to ask.
Good luck
ajblaj
Sep 06, 2010 | Nintendo Wii Console
My Samsung CLP 310 won't come out of sleep mode preventing me from printing. How do I wake it up. There's nothing in the manual or in Samsung's troubleshooting guide.
I finally got my CLP325W waking up correctly from sleep, but I made a few changes at once and don't know for certain which one (or combination) worked. Here are my changes:
1. disabled the USB port. (I had originally set up the printer via this port).
2. disabled IPv6 support.
3. disabled the dynamic DNS registration.
4. enabled telnet (though I doubt this had any effect).
My setup uses a static ip address that is outside the range of the dynamic addresses my router assigns and I use a mac filter on my router without any problems.
Apr 29, 2010 | Samsung CLP-315W Laser Color Printer
Adapter wire troubleshooting
Cable modems often don't work with a router unless you do something called cloning your MAC address. The MAC address is a unique number assigned to each device's network connection. Unless the cable modem sees the MAC address of the computer originally used to set up service it often won't connect. Cloning the MAC address in the router gives it the same address as your computer, and that usually gets the connection going.
You'll find the link for cloning the MAC address in the router setup screens. Rather than go through the steps here, I suggest you download the manual for your version from Belkin or look at the copy on the CD that came with the router. I don't know which version of the router you have, so the manual I was looking at may not be exactly the same as yours.
Make sure you have the computer originally used to set up your cable Internet service connected to one of the router's wired ports. Follow the steps in the Alternate Setup section to move through the various screens until you reach the link to change the MAC address, and that's where you'll copy the address from your computer to the router. Once that's done your modem and the router should play nice together, and you'll be back online.
Hope this helps, and thanks for using Fixya!
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
761 people viewed this question
Alun Cox
David Payne
David Payne
