Directv Samsung problem
I had Directv install HD satellite and H21-200 processor connected by 6 foot HDMI cable to my Samsung LNT3242H TV. HD works great but digital channels are very fuzzy. We tried two different processors but no improvement. Next ran a different new cable from the dish directly to the processor but no change. Technician set up for AV1 to get slight improvement but picture quality on digital channels still poor. Tried another Dell TV and no change. The tech wants to try another TV from their inventory to see if that fixes the problem--his 3rd trip back to try to fix the problem. Anyone got any idea what the problem with non-HD channels is?
  • kentof Mar 02, 2008
    Any help would be appreciated
  • kentof Mar 03, 2008
    Thanks for your help
  • 103 Answers
I also have directv.At this point,it is a video signal issue on their end.The up conversion is ok at best.Depending on the original video that is probably as good as it gets.The other problem is the wow factor from hd.It is hard not to be critical of the non-hd channels.
Posted on Mar 03, 2008
I lose volume on HD channels with Directv
Reset the Directv box,by unplug it,replug it and hour later to let the last software to update.Replaced the HDMI cable,goto ur tv menu,goto sound functions,go down to reset it back to the factory setting.After this the the sound functions should be stable,and work.Not,than ur Tuner signal board have some kind of intermittion short in the board.Than must replaced the Tuner board to solved this problems.
Apr 16, 2010 | Samsung LNT3242H Television
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
I have a Samsung 32" series 3 tv and a basic satellite box (Directv) without an HDMI outlet. what is the best way to install?
The only option you have with a standard DirecTV box is using composite or s-video connection to your TV. These are much better options than using the RF tuner input and will give you stereo audio. Please take a few moments to rate my answer. Thanks...
Dec 03, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Televison & Video Logo
286 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
