Question about Refrigerators
Kenmore elite ice maker doesn't work MOD 53702200
Hi I have a Kenmore elite side by side. All of the sudden it stop making ice, It is 5 or 6 years old, never had a problem before. We notice that the light right next to the ice maker switch (sensor ??) is off. Water comes out through the water dispenser on the door. Please HELP
  • 2 more comments
  • Anonymous May 02, 2008
    1. I BELIEVE THE ICE MAKER SENSOR WENT OUT. HAS ANYONE HAD THIS PROBLEM, AND IF SO HOW DID YOU FIX IT.
  • Anonymous May 14, 2008
    4 year old Kenmore side by side and the Ice Maker just quit.
    Don't speak enough foreign language to talk to the 800#
    Has anyone got theirs fix'd??
  • Anonymous Jul 04, 2008
    My 2 year old Kenmore Elite is not dispensing ice. We're getting plenty of ice cubes but can't dispense them. I've cleaned the storage bin but the cubes just won't drop. Any ideas?
  • Cathy Zannis Mar 07, 2009
    Our Kenmore refrigerator Model # 106.56689501 is only three years old. I had the Icemaker replaced already three months ago and already it is not working again. Is there anyone out there who knows what the solution to this problem is?
HVACRH20
  • 237 Answers
SOURCE: No water from dispenser
If the ice maker is still working then water of course isn't an issue. The water dispensor has a solenoid valve that opens to let water flow... do you hear a "click" from the back of the frige when the water lever is pushed? If not, the valve is likely bad. Another possibility is the switch behind the water lever itself is not being pressed hard enough or even broken, see if you can press the switch with your finger up inside behind the lever area (flashlight needed to see up there). If that lever isn't hitting the switch it won't work of course but it could be a bad switch too. Sometimes the little plastic pins that hold the switch in place get broken by slamming a glass into the lever over time. In other words the switch is fine but just hanging inside the door area never to be hit by the lever again. I would be good to check it by pulling the cover off that are and visually inspecting the whole back side of the lever area/switch are for broken parts. The link below may help you with parts and diagrams to see the unit better. http://www.partselect.com/KenmoreModels.aspx?ModelNum=106.54382300&searchTerm=
Posted on Nov 24, 2006
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
The power was off at my huose for 12 hours. When I removed the ice bucket I saw that water condensated and was now frozen around the shaft of the ice dispenser moter. The ice was prevent edthe motor shaft from turning.. I used a pair of needle nose pliers to loosen the 2 mouting bolts of the ice dispense motor approx 1/4 turn and all is well.
My wife thinks it's a miracle and that's all that matters!!!
Posted on Sep 15, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
Posted on Jul 29, 2010
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
Ice maker not working mod 10653604201
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hdghd7
Jun 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker problem
Here are some basic tips for ice maker troubleshooting2_bing.gif...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
1,260 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
