Question about Hamilton Beach Stay or Go 45234 Coffee Maker
Drips onto counter when pouring from carafe
This coffee maker can not be recommended as it leaks down the side of the carafe when pouring making a mess on the counter. I would never have bought this coffee maker had I known about this problem. I am going to call hamilton beach to see if they will replace with one that works.
  • 4 more comments
  • Anonymous Apr 08, 2008
    Yes we had same problem with ours. E-mailed factory they said to mahe sure white seal is flush with lid.(It was & it stills drips coffee everywhere.
  • Anonymous Aug 17, 2008
    I have tried pressing the release button both before and after tilting the carafe. Same problem with dripping down the side. However, after a couple of cups are poured, the problem disappears.
  • hmslinda Oct 16, 2008
    This is the drippiest coffee carafe ever! No matter how you pour it, it drips down the carafe all over the counter. I keep it in the sink now until I replace the maker. Very poor qualilty control on the coffee carafe.
  • Kim Gough
    Kim Gough Jan 11, 2009
    Mine does the same thing. Let me know if you have any luck
  • Anonymous Mar 30, 2009
    I love the idea of an insulated carafe coffee pot but don't feel that one should have to jump through hoops just to use this pot. so I went out and bought a different brand and all is well.
  • mv102858 Apr 20, 2009
    Coffee leaks down the side of the carafe while pouring.
My carafe for my h/b stay or go coffee pot started leaking after owning it for a while. This appeared to be a perplexing problem until I discovered that the small gasket on the bottom of the lid had either flattened out over time, or rotated to a different position that would cause my pot to leak or dribble coffee all over my cup and counter top. To fix this I just rotated the gasket to a spot where it would create a good seal. Every so often I have to repeat this process, and I need to contact Hamilton Beach to see if they can send me a new replacement gasket, as a new gasket would solve the problem.
Posted on Oct 19, 2010
Correct. This is due to the surface tension of water. Water likes to stick to things (meniscus, capillary action, etc). This carafe's spout makes it difficult -- but not impossible -- to pour without drips. Here's why, and then a tip: As you pour, the coffee wants to cling to the spout and follow the pot down, rather than pour away from the spout. You *can* oil the spout, sure, since water molecules and oil molecules hate each other. Coffee's water will release immediately, preferring to stick to other water molecules and not the spout (hence, no drips). But then again, all you have to do is refrain from depressing the lever that pours the coffee until you've tilted the pot enough that the coffee gives up to gravity. In other words, tilt your carafe to your cup as close to 90° as you can before thumbing the lever to release coffee. When the cup is about full, let go of the lever to shut the flow off. Now tip the carafe upright. No drips! (or sometimes, maybe a single drip will try to run down).
Posted on Mar 30, 2009
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Posted on Feb 01, 2009
    New Friend:
  • 3 Answers
Cut the rubber seal inside where the spout is 1" wide. This stops the coffee from getting caught in the seal and running down the side.
Posted on Nov 13, 2015
  • 102 Answers
Use medium grit sandpaper to roughen the surface of the pouring spout, including the spouts edge and the area around it.
Posted on Apr 10, 2010
DCC 2400 COFFEMAKER LEAKS CONSTANTLY. ALL OVER THE COUNTER. HAVE CLEANED IT. IS IT FIXABLE SHOULD I TRASH IT?
I had this problem.
The Fix:
There is a valve in the centre of the carafe lid (If you shake the lid you can hear the valve rattle). This valve becomes gummed up with heavy coffee oils over time and sticks causing part of your brew to pour onto your counter. The fix is to simply clean the oil out of this valve. I cleaned mine by soaking it overnight in a water/bleach solution then blasting hot water into it. You can clean it more thoroughly if you pop off the bottom lid part that extends into the pot. It is a snap fit. Before you take it off note the orientation.
On my lid this valve was coated in heavy, greasy coffee oils. After this cleaning your pot should not leak when brewing.
Another problem is the stiffness of the lid making it sometimes very difficult to open and close and if not fully closed coffee will leak while pouring. This o-ring binds against the carafe. To fix this, locate the 'O' ring in that same part the extends into the carafe on the bottom of the lid. put a drop or two of vegetable oil on your finger and apply a thin film around this ring once every three weeks or so. Your lid will open and close smoothly and beautifully.
Happy brewing!
Feb 22, 2011 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart DC 1150 (10 cup) coffee maker leaks out of the top.
I have experienced this same problem. You have to pour the water directly into the holding bay, avoiding the edges. I think water gets stuck around the rim, it just steams over the edge, or drips down the front and back onto the counter. I don't know why, but it happens, so just make sure you pour the water directly into the bay avoiding edges.
Nov 27, 2010 | Cuisinart DCC-1200 Coffee Maker
Our brand new Cuisinart model DCC-1150 10 cup coffee maker with the stainless steel thermal carafe makes a great tasting cup of coffee but the coffee isn't piping hot when first made and the carafe doesn't...
I am having the same problem, along with the coffee leaking onto the counter. I think this coffee pot is just defective. If not, I wish someone would come up with an answer.
Oct 21, 2010 | Cuisinart (DCC1150) 10Cup Coffee Maker
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Overflowing basket
The grind on your coffee is too fine, and if not there is too much coffee in the basket, hence the overflow.
Jan 02, 2009 | Wega Mininova EPU Espresso Machine
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Bunn coffeemaker
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Jul 14, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Hamilton Beach Stay or Go 45234 Coffee Maker Logo
1,048 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
