Question about Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN437W The TV comes on the picture turns within a 10 to 12 seconds. I continue to get sound but need to turn the tv on again the problems persists. Occasionally the picture appears to be inverted and upside down????
  • Samsung Master
  • 8,617 Answers
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
Posted on Mar 02, 2008
Not sure how to get to service mode??
Posted on Mar 03, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I have a Sony wega old style tv and the standby
The reason that that TV does that is because it needs a new lamp there's a lamp that can be installed in that TV you can search Amazon for the part you need and that should correct the problem especially if you have sound and no video
Jan 24, 2018 | Televison & Video
TV Screen 'freezing' while watching.
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Nov 18, 2009 | Samsung HLN437W 43" Rear Projection HDTV
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Picture freezes Black/White
It's most likely the digital board, Samsung p/n# Bp94-00385a but I'd trace test both the digital and analog first before blindly replacing it - too costly to just guess..
Bill
Dec 08, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Open Questions:
Samsung HLN437W 43" Rear Projection HDTV Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
