Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
When i close the door to the machine the door lock light flickers but wont stay on, which in turn the machine wont start its cycle as it thinks the door isn't locked. Do i need a new door or a new switch?
Man thanks
Charlie Middleton
  • 2 more comments
  • plumbsuk Mar 02, 2008
    Thanks for getting back so quick!
    We can see the light flicker on when we slam it hard but it wont stay on. Also if i close the door and bag the side of the door, the light flickers as well.
    Kind Regards
    I'll give it a try and let you know!
    Many thanks again!
  • plumbsuk Mar 06, 2008
    I've played around with the switch got it fill but when it goes to drain or spin, the doorlock light fades and you hear a buzzing noise.
  • Anonymous Mar 26, 2014
    Door need pushed very hard to start the cycle
    Problem Solver:
  • 14 Answers
Sounds like a bad connection some where, maybe the switch, but probably a bad or loose connection, maybe a ground. check junctions, & connections
Posted on Jan 08, 2012
    President:
  • 1,314 Answers
You may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Posted on Mar 02, 2008
  • robert samples Mar 02, 2008
    check the connections then replace the switch make sure the part on the door isnt broken
    id check the outlet for proper voltage first and do a voltage drop test that is plug a volt meter in the same out let where the washer is take a reading then turn the washer on and see if the voltage drops 12 volts or more its a power problem
I have just bought a hotpoint aqaurius washing machine model no. WMF740. THe power to it is o.k. but when I press the power button the machine does not light up. Can you help
MOST WASHING MACHINES HAVE A SWITCH ON THE DOOR , WHEN THE DOOR IS CLOSED THE SWITCH ACTIVATES OR TURNS ON THE WASHER. THIS IS A SAFETY TYPE SWITCH TO PREVENT IT FROM RUNNING WITH THE DOOR OPEN. CHECK THIS SWITCH TO SEE IF IT IS LOSE OR NEEDS ADJUSTING. IF THIS DOES NOT FIX THE PROBLEM, THERE THEN MAY BE A SENSOR OR OTHER SWITCH THAT NEEDS REPLACING. THIS WILL REQUIRE AN APPLIANCE REPAIR MAN TO REPLACE THE SWITCH OR SENSOR. - - SORRY
Feb 20, 2011 | Hotpoint Washing Machines
I want instruction manual for WD62 aqaurius washer dryer
Hi
I have one. I can scan it for you but not sure what to do with it then!
Jun 17, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 washer dryer does not start indicater light doesnot light up. have checked line fuse and socket thanks
It is probably a faulty door lock, a common problem.
Remove front of door seal by releasing the wire clamp, and unscrew door lock, it has 3 wires going to it, to prove it is the door lock, short out the 2 wires marked C and L ,it should now work, if it does not , then the fault is elsewhere,, but I feel confident this is the problem.
Please rate my solution.
Feb 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD61. Door lock light went out before drum stopped after spin prog, now can't get anything to work. I think the Door micro switch or plug fuse... Can you think of anything else to check? How do I...
hi you need to take off the clip thats around the seal ..pull seal away....the switch is held in with two scews ************** TURN APPLIANCE OFF AT WALL PULL PLUG OUT ************** undo scews take interlock out and replace.hope this helps.01179512835
Dec 30, 2009 | Hotpoint WD62 Front Load Washer / Dryer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Fixing of door hinge?
undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Aug 14, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
631 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
