Question about Creda W100FW Front Load Washer
Creda W100FW will not take the powder from dispencer and stops during wash
Hi I have a Creda W100FW which will not take the powder from dispencer and stops during wash? All suggestions welcome.
Regards
Dave
  • mv600prob Mar 05, 2008
    Thanks, Water supply and pressure seem OK. Which brushes are you refering to?
  • 67 Answers
Check water supply is on, also you can get low pressure which can cause this problem you could try tablets. and poss your brushes are worn out
Posted on Mar 03, 2008
  • Darren Moxam
    Darren Moxam Mar 06, 2008
    Im sorry the brushes wont cause that problem. Iassume that you are putting the soap in the right compartment. Also if it tablets that you are using some they stay in the drawer because the water isnt running long enough to dissolve the soap. As for the sticking on prog it's poss that your heater could be faulty.
Creda water level sensor
You have a blockage in the syphon assy or a split syphon pipe
Sep 08, 2012 | Creda W100FW Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Where is the filter ?
Remove lower rear panel locate and remove large black hose at bottom right of washer, and clean filter ionside hose
Please rate my solution.
Thanks.
Jun 28, 2009 | Creda W100FW Front Load Washer
I have a Creda W200FW. The rubber packing of the front door is full of black mold and smells bad. What kind of detergent is good to get rid of them. I have moved to a renging house and the washing machine...
Hi , Bleach will get rid of the black mold and stop it coming back for a while. Don't leave it on too long as bleach has a hardening effect on rubber. If you occasionally give it a wipe with a mild bleach based cleaner it will stop it coming back.
Jun 08, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Apr 04, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
98 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
