Question about Sony Playstation 3 (PS3) Console
Cannot locate hard disk drive...
When i power on the system the green and blue light flashes and then it power off. and then it shows that it cannot locate the hard disk drive...
No picture and no connection???????
  • Anonymous Apr 29, 2008
    cannot find hard disc
Its because the HDD (hard disk drive) has failed. Just replace with any SATA 2.5'' Laptop HDD. Install. Power on. And follow the setup.
Posted on Mar 03, 2008
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
My simpledrive has a flashing blue light and does not show on pc
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 22, 2012 | SimpleTech Computers & Internet
I am not getting power to the external hard drive. when i plug in the ac adapter, i get a flashing green light on the adapter but no power to the disk. could the ac adapter be bad?
It's probably _NOT_ the AC adapter, given that the lamp is "green".
Disassemble the casing, and temporarily connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk itself is still functioning & its files can be read.
Mar 03, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Oct 15, 2009 | Advent Netbook
Buffalo USB drive is not located by Mac Powerbook when connected
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Jul 21, 2009 | Computers & Internet
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
Flashing Green Light next to voltage switch
For problem #1 there is a MBR (Master Boot Record) problem, meaning that Windows is unable to find Windows. This can either be a software problem or a hard disk failure. If you have your Windows XP disc boot up with it in your cd drive and when it starts press 'R' for repair as this wil repair system files and you will not lose any settings or doc's. When you are running go to your hard disk drive manufacturer and run a diagnosis and repair if neccassary. Problem #2 should sort itself out if left unplugged from the mains supply and the power supply unit for 15 mins or so. If not there is a power supply that needs replacing.
Nov 06, 2006 | Gateway 505GR PC Desktop
Sony Playstation 3 (PS3) Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
