My color TV has no color
The menu screen comes in blue. The chanel #s come in red or greenbut all the programs come in black and white I tried to adjust the color by going to the set menu but it didn't work The TV is a13inch Orion
  • eldermac Dec 18, 2008
    I have the exact same problem on a 27 inch Sanyo. No color on the programs but menu screens and channels come in color.
Your tv is broken
Posted on Mar 04, 2008
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
LT32HVE only in black and white with component inputs...definitely the proper red is plugged in because we swapped it just in case and it did not change the problem. Also when trying to bring up the menu...
On component inputs the color is carried by the green connection. I would check your green cable. It also carries the video which you seem to have. Since the menu comes up black and white also does it do this in composite also? If it does it is most likely your main board. If your green blue and red cables are ok and you still have black and white it is also most likely your main board. Component uses digital portion of main board. Composite does not
Oct 22, 2010 | Olevia LT32HVE 32 in. LCD Television
My GE 35GT695 has lost color and will only show in black & white. However, when I press the menu button the menu shows in color while the screen is still black & white.
the on screen graphics are sourced from red,green ,blue drives,..your fault is with the colour decoder .sorry it is a repair that needs a expert engineer ..it could be dry jointed to test for dry joints try tapping the back cover or bottom of the set ..good luck farr64[colin]
Dec 29, 2009 | GE 35GT695 TV
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Blue screen
the problem of ur tv is tuner,try to solder the tuner
Sep 28, 2008 | JVC AV-27120 27" TV
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
