Question about Goldstar MA-780M Microwave Oven
Turntable not moving, otherwise micriwave works.
  • 2,130 Answers
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessorTurntable not moving - 2.gif also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 02, 2008
Oven seems to be working with the exception of the turntable not revolving
Check that there is no damage to the plastic turntable rotor (i.e the part with wheels) underside the plate. Motor could be working but rotor missing or not connected properly, or damaged. Otherwise the turntable motor or motor driver circuit is fried.
Feb 04, 2015 | Microwave Ovens
GE Microwave PVM1790DR1BB light works but no fan and the turntable does not turn
I have this exact model with the same issue. I am a technician by trade on office equipment. I took the cover off where the door latches go in and there are 3 relay switches behind there. I adjusted the switches so the door latch would make better contact with them.
May 05, 2013 | Microwave Ovens
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Aug 02, 2012 | GE Microwave Ovens
TURN TABLE NOT ROTATING
see the nex step and proceed with common sense and logically: God bless you
Jul 26, 2012 | GE Microwave Ovens
Turntable will not rotate.
Hi.when the turntable is not workinh, then there is a problem with the MOTOR inside the oven.MOTOR is responsible of rotating the turntable.To check further ,back portion of the oven must be removed to check further the motor.Using a tester yuo can check the continuity of the motor by setting it to OHMS.if the testers pointers move a little it means motor is not short -circuited if otherwise it moves to its maximum amount it means MOTOR is short-circuited and yuo have to replace it with a new one .Hope this helps.
Jul 06, 2011 | Emerson MW8107WA Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Kenmore micriwave won't heat!
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Your biggest suspects will be a bad connection or relay on the control panel, a bad connection on the magnetron terminals, a bad magnetron, a shorted high voltage rectifier diode or a bad high voltage transformer.
You can find exploded views and part numbers by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You may be able to find better part prices than Sears here.
Your magnetron may have a 5-9 year warranty, so check your manual for that. Sears may send you a magnetron if it's bad and warranty.
Oct 20, 2008 | Kenmore 62702 Microwave Oven
Turntable doesn't turn
If you just purchased and Installed the microwave, I would call Sears and tell them what is happening, generally, it would still be under warranty if less than a year old. If its a countertop model, you may have to take it in, otherwise they should come to the home for the repair. I would also NOT indicate that you have looked at it as that would void your warranty.
Otherwise, it seems like the problem could be, a) touchpad , b) a relay or c) the main control board
Feb 02, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Turntable does not work
Need to check if you have power to the turntable motor. Either is has a bad motor or a bad relay on the control board.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar MA-780M Microwave Oven Logo
118 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
