Question about Car Audio & Video
Looking for color code wiring , back up light 2006 ford mustang
Looking for color codes wiring back up light, 2006 ford mustang
    Problem Solver:
  • 51 Answers
Please check www.playpower.com.cn
Posted on Mar 18, 2008
2006 ford mustang side marker lights do not work
I have never heard this complaint on this generation of Mustang. I can direct you to the wiring diagrams and you can trace it down, my guess is a connector is not fully locked maybe in the rear. http://bbbind.com/free_tsb.html
Nov 07, 2013 | 2006 Ford Mustang
Color codes for 2006 ford 150 to taillights
first ck under and see if connector for trailer is there. if so use it,test each wire with test light to see whats what. or pull lt taillamp and trace wires back and splice in .
Aug 02, 2012 | 2006 Ford F-150
2006 ford mustang , emmision light turned on !! HELP!! Please
Is this an amber colored lamp? In most cases this is just a reminder to have your emissions system checked for possible worn hoses, vacuum lines, belts and amongst other thing, There should be a section in your owner's manual with direction on how to reset the lamp.
Let me know if this helps
Rodney
Jun 14, 2011 | 2006 Ford Mustang
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Jul 01, 2010 | 2001 Ford Mustang
2006 ford mustang front right parking light stays on at all times and drains the battery is there a stuck switch?
With only one light staying on, it won't be a switch.
To start troubleshooting, swap the 2 front bulbs. If the problem follows the same bulb, replace the bulb. If it doesn't, you may have a power wire issue somewhere and would take a little more troubleshooting.
If the bulb filament is too close to each other, it can keep it on. I had it happen on a previous vehicle.
If this doesn't get you a solution, please come back.
Oct 18, 2009 | 2006 Ford Mustang
My car was stolen and some one cut all the wires
reconnect the wires buy buying but connectors and connect the wire to each color coded wire. match up green to green black to black black with green stripe to black with green stripe. You can go to www.alldatadiy.com to look at the wiring codes, cost $24.00 for one year for your car. if your not able to use a pair of wire crimps then you may wat to take it to a shop.
Aug 30, 2009 | 2001 Ford Mustang
Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Apr 11, 2009 | 2006 Ford Expedition
Car Audio & Video Logo
254 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
