Question about Maxtor Hard Drive
I would like the diagram to switch an old hdd16.9g from master to slave
Model 91728d8,hda/uplevel 08a,pcba/uplevel 02a, unique/uplevel 11a
cylinders 16383, heads 16,sectors 63,jumper j50
thanks
jpcote36@rogers.com
    Genius:
  • 1,027 Answers
If by the diagram you mean jumper settings try this web site, if your drive is not there check the product index page.
http://support.seagate.com/rightnow/images/maxtor_quantum%20jumpers.htm
Posted on Mar 02, 2008
Parts diagram for clutch slave cylinder nissan D40
It's easy put new master cylinder in place but don't connect rod to clutch pedal or bolt it to bulk head and leave metal solace feed pipe undone , connect fluid feed pipe to cylinder then tilt cylinder so slsve out let faces more down wards then top up fluid pot when fluid runs out slave outlet reconnect slave pipe , bolts master cylinder back in place and connect pedal to it , then undo nipple on slave cylinder let fluid run out freely titghten niplle then pump clutch pedal until it becomes firm job done .
15 minute job .
Nov 07, 2015 | 2007 Nissan Navara 2.5
Clutch pedal diagram
go to the wreckers and get all the parts out of a manual cab the same as yours . You will need a clutch master cylinder and slave cylinder as well as the piping from one to the other ( get new master/ slave cylinder as it will reduce the possibility of hydraulic problems . If it is going to be a cable clutch then get everything associated with a cable including the correct throw out lever in the bell housing.
Jan 02, 2014 | Cars & Trucks
I have 94 Mazda mx-3 for the past month or so I've been having problems with my clutch and I notice a big wet stain on the floor mat and carpet I assume its the master cylinder or slave cylinder but I am...
It's leaking on the driver's side? That would be the master cylinder bolted onto the firewall. You will have to replace with a new or remanufactured clutch master cylinder. When the seals go out, the whole unit must be rebuilt. The store will give you a discount if you bring in your old one for exchange.
The clutch slave cylinder will be down on the transmission bell housing. Follow the small steel line from the master cylinder. It goes right to the slave cylinder.
Pretty easy to change out the master cylinder. Remove the steel line, unbolt unit from the firewall, then under the dash, there's a rod from the clutch pedal to the master cylinder. Just undo the retaining clip or pin holding the rod to the pedal. When the new unit is installed and filled with fluid, then you get to learn how to bleed the hydraulic clutch at the slave cylinder-the fun never stops.
Oct 31, 2013 | Cars & Trucks
How to replace old fluid for the clutch?
If your clutch will not engage when the piston is pushed in fully, you probably have air in the slave, the line , or the master cylinder. Place a piece of plastic and an old towel over the bike to catch any drips. Remove the top master cylinder cover and take an old, clean, lint free, cotton sock and gently soak up all the old brake fluid in the master reservoir. Place the sock into a used zip lock bag and discard. DO NOT touch the clutch/brake lever or you will draw air onto the system. Now fill the reservoir with DOT 3/4 brake fluid and bleed the slave cylinder. Warning: be careful not to spill DOT Brake fluid on your paint or plastic. Place a tube on the bleeder screw (slave cylinder) and loosen the bleeder screw. now pump the lever to push the air out of the system. Hint: if you do not have pressure in the master, loosen the brake hose banjo bolt enough to burp the air out of the master(2 or 3 pumps of the lever). Retighten the banjo bolt and bleed the rest of the system.
Bleeding the system should restore clutch performance. If you notice fluid leaking from the master or slave cylinder , replace the o-rings in the slave cylinder piston and rebuild the master cylinder. A master cylinder kit and slave cylinder o-rings are available at your local Honda dealer.
Feb 08, 2011 | 2001 Suzuki VL 1500 Intruder LC
My 1996 Chevrolet K3500 Dually has a hydraulic clutch, how do I change the fluid and bleed it.
FIRST REMOVE ALL OLD FLUID FROM CLUTCH MASTER CYLINDER YOU CAN USE A SIPHON YOU HAND PUMP.AUTO PARTS STORES SELLS THE HAND PUMP SIPHONS. THEY DONT COST MUCH AND KEEP FROM MAKING A MESS.SIPHON OUT MUCH AS YOU CAN THE OLD FLUID IN THE CLUTCH MASTER CYLINDER.THEN POUR IN THE NEW FLUID DOT 3 BRAKE FLUID IN CLUTCH MASTER CYLINDER.OKAY YOU NEED A HELPER.LOCATE THE SLAVE CYLINDER.REMOVE SLAVE CYLINDER HOLD SLAVE CYLINDER 45 DEGREES WITH BLEEDER SCREW LOCATED AT THE HIGHEST POINT.HAVE A SMALL DRAIN PAN UNDER SLAVE CYLINDER.HAVE HELPER FULLY DEPRESS AND HOLD THE CLUTCH PEDAL THEN OPEN BLEED SCREW.CLOSE THE BLEED SCREW AND HAVE HELPER RELEASE THE CLUTCH PEDAL.REPEAT THIS PROCESS UNTIL ALL THE OLD BRAKE FLUID AND AIR BUBBLES LEAVES THE HYDRALIC SYSTEM AND WHEN YOU CAN SEE GOOD STREAM CLEAN FLUID NO BUBBLES YOU HAVE GOOD SOLID CLUTCH ALL IS GOOD.MAKE SURE THROUGH THE BLEEDING PROCESS YOU DONT LET CLUTCH MASTER CYLINDER RUN DRY OR YOU WILL HAVE TO START OVER.KEEP CLUTCH MASTER CYLINER FULL BRAKE FLUID WHILE DOING THE WHOLE BLEEDING AND FLUSHING PROCESS.
Jan 22, 2011 | 1996 Chevrolet C/K 3500
I have a 1990 Isuzu trooper i am wondering what is n line between the clutch master cylinder and the slave cylinder
You mean brake fluid?? There should be nothing in between the master and slave, unless you have a switch of some sort, but being that old, I doubt it. I really don't understand your question, but hope this helps.
Oct 17, 2010 | 1990 Isuzu Trooper
Slave Jumper settings NEEDED on Maxtor 9172808 ...17 G Hdd
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Looks like the model number is 91728D8 for 17 Gb HDD DiamondMax 4320 Ultra ATA. Hope this helps.
Jul 10, 2009 | Computers & Internet
1994 Jeep Wrangler 4cyl - Bleeding slave cylinder
This is not a bleeder hole, this is a weep hole like in a water pump to see when there is seepage past the seals.
Bench bleed the system. With the master cyl. line and slave cyl assembled, place the master cylinder in a vise, fill the master cyllinder. actuate the slave cylinder back and forth lower than the master cyl. This will allow the air to escape upwards back into and out of the master cyl.
Once bled the system can be installed.
Good Luck
Aug 06, 2008 | 1994 Jeep Wrangler
How do I change jumper settings on Maxtor hard drive, model: 51024h2, hda: 02a, pcba: 61a?
Here's the manual for your drive.
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_40_ultra_ata_100_manual.pdf
I think the section you need is 2-5. You will need to disconnect the drive from power and the ribbon cable. Use gentle pressure to remove the cables.
If you aren't able to remove the jumpers by hand, I would suggest using tweezers or something similar.
Thanks
Jul 22, 2008 | Computers & Internet
Maxtor Hard Drive Logo
219 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
