Question about Lanier 260T Desktop Cassette Voice Recorder
Lanier Transcriber unit will not play
I have a Lanier VW260 and it will fast forward, rewind but will not playback tapes. It has worked fine in the past but all of a sudden quit working. Any suggestions?
Thanks
  • terrij Jun 20, 2008
    I just acquired a Lanier VW-210 and it does the same thing. I do not have a users manual so I have no clue as to what is wrong
  • tsclock May 11, 2009
    Hello DACA Dave, I have a couple machines to be repaires. How to I contact you?
    Best regards,
    SG - please contact me at the address below or call me at (402) 430-6140
    info@theswissclock.com
    Problem Solver:
  • 7 Answers
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Posted on Jul 16, 2008
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Audio Players & Recorders
I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Sep 20, 2011 | Lanier Audio Players & Recorders
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Lanier 260T Desktop Cassette Voice Recorder Logo
494 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
